SRT6 vs Regular Crossfire rear
Old Oct 28, 2008 | 03:09 PM
Bulldogger's Avatar
Default SRT6 vs Regular Crossfire rear
I spoke to Gary about building a posi unit for the SRT6. The question is, is the rear carrier the same on both cars? I know the gearing is different but what about the differential. Also if anyone has a spare differential he would only need it for about 2-3 days to see if he can build a limited slip differential.
Old Oct 28, 2008 | 03:29 PM
tighed1's Avatar
Default Re: SRT6 vs Regular Crossfire rear
I did a simple SEARCH and found this.
You started a couple of threads in reference to rear end stuff.
Just what are you up to anyway????
https://www.crossfireforum.org/forum...erential+gears
Any help?
Old Oct 28, 2008 | 03:56 PM
Bulldogger's Avatar
I want a real good limited slip differential. Since quaife doesn't make one, Gary Peloquin in Geogia said he probably could. He would need a pumpkin to check the size and see if everything would fit. Obviously if the regular crossfires have the same pumpkin with just a different gear ratio, then there would probably be a pretty decent market for a top notch LSD. If the demand is there then I sure he would go a head and make us one. Now if we can confirm that they are the same, I will get a rear and send it down to him or he can maybe find one in a junk yard.
Old Oct 29, 2008 | 03:25 AM
BLACKSRT-6's Avatar
I have a complete spare unit out of a base model crossfire that I pick up for the shorter gears. It measures out the same, but I have not put it up in the car. I'd be happy to have my unit be the test product.
Old Oct 29, 2008 | 05:48 AM
sonoronos's Avatar
Just send it to Gary, regardless of whether it is limited or SRT6. In my opinion, he should have access to both types. Just make sure he knows which one he is making, so when he makes more for other people, he knows what he's actually selling!
Old Oct 29, 2008 | 05:52 AM
Bulldogger's Avatar
If it is the same exact rear with only a different ring and pinion there would be no point, obviously the LSD would work in all the crossfires.
Old Oct 29, 2008 | 06:04 AM
sowardcustoms's Avatar
the case is the same the only difference is the ring and pinion and the yoke (flange) for the driveshaft.....
Old Oct 29, 2008 | 06:32 AM
sonoronos's Avatar
I don't think ya get it - Peloquin does not have a single XF diff, not limited, SRT6, or otherwise. So my point is to send it in, regardless of what type it is, and if they are identical then all the better.
Old Oct 29, 2008 | 06:52 AM
Bulldogger's Avatar
Yea I get it but you said send both, he will only need one case to see if it can be done. BlackSRT-6 has a spare to send to him, If he doesn't want to send it then I'll try and find one at a junk yard, not gonna pull mine because car is do over at Kooks Headers Nov,11.
Old Oct 29, 2008 | 07:13 AM
BLACKSRT-6's Avatar
Got your PM, I will give you a call. Thanks
Old Oct 29, 2008 | 08:13 AM
BLACKSRT-6's Avatar
I spoke with Gary and will be sending him my Pumpkin this weekend.
Old Oct 29, 2008 | 08:42 AM
Bulldogger's Avatar
Excellent, I hope he can do it.
Old Oct 29, 2008 | 10:06 AM
daun's Avatar
The differential housing is equal. The ratio is at SRT longer than the base model. I have converted my SRT with a 60% differential lock and a modified ESP software with 100 %-ESP-OFF function . Supplier is Väth in germany (www.vaeth.com).I'm very satisfied, because the acceleration in wet road is much better.
Old Oct 29, 2008 | 10:29 AM
tighed1's Avatar
Dang, I don't do German anymore.
I was able to look at the pictures!
Old Oct 29, 2008 | 12:36 PM
Opticon's Avatar
So Gary Peloquin will have the SRT6 diff to test?
Progress!
Old Oct 29, 2008 | 12:57 PM
Bulldogger's Avatar
Yes big thanks to BLACKSRT-6
Old Oct 29, 2008 | 01:13 PM
ImportLabSRT's Avatar
When I get my winter beater up and running.... If no one has sent in a SRT-6 diff and he still needs one, I can drop mine out and send it in.
KDW4Him
Jul 10, 2015 12:04 PM
TomSRT
Jul 3, 2015 08:10 AM
SRT SIX
Jun 22, 2015 05:37 PM
racingagent
Jun 8, 2015 07:29 PM
MJPowers
Jun 8, 2015 02:34 AM
