Help me get part number for plastic passenger splash guard...
Old Nov 1, 2008 | 11:11 AM
ohnoesaz's Avatar
Default Help me get part number for plastic passenger splash guard...
Ya know I'm usually really good at looking up part numbers but I'm out of luck on this one.
I need the part number for the splash shield thing on the passenger side, beneath the car, facing down, right below the heat exchanger water pump. To the side of it is the main center splash shield. I'm sure you know which piece I'm talking about....
I did a bad job reinstalling this piece and found it out when it went crunch crunch under my tire as i was driving....
Old Nov 1, 2008 | 01:18 PM
robby363's Avatar
Default Re: Help me get part number for plastic passenger splashguard..
If it's the shield that's below the fog light this is part# 5097998AA and this one is the same but includes the access door that goes on it. 5098682AA
Old Nov 1, 2008 | 02:45 PM
ohnoesaz's Avatar
wow the dealer wants $116. How about no... I may just have to fab up something crude. I only lost the lower flat-laying section, not the section around the wheel well.
Old Nov 1, 2008 | 02:54 PM
robby363's Avatar
Parts.com has the whole part.http://www.parts.com/oemcatalog/inde...eid=7&siteid=2 And wthout the access door panel.http://www.parts.com/oemcatalog/inde...eid=7&siteid=2
Old Nov 2, 2008 | 03:31 PM
KrzyFast's Avatar
Default Re: Help me get part number for plastic passenger splash guard...
Are you talking about the air diverter or air deflector in front of the front right tire? ...hangs down about 2" and is about 4" wide?
If that is what we are talking about it is NOT worth $116! You could make your own for less than $5
Old Nov 3, 2008 | 05:25 AM
sowardcustoms's Avatar
i can sell you the part #5097998aa it is the splash shield without the fog light door for $59.00 plus freight give my your zip and i can get you a quote? will ship tomorrow if i know by 5:00pm no tax if your out of state....
Old Nov 3, 2008 | 08:46 AM
ohnoesaz's Avatar
Thanks guys.
I only lost the bottom part of it. It tore off from the part that goes near the tire. And actually, I didn't lose it, I turned my car around and found it haha.
So, I decided I will just figure out a way to mount it as-is, because this way I'll be able to remove the now-separate bottom part easily if I want to install a new I/C pump or something.
Thanks for coming to my rescue!
Old Nov 3, 2008 | 09:20 AM
tighed1's Avatar
So what were ya doing in there? Did ya get a new I/C pump?
Anymore issues with your pulley?
Old Nov 3, 2008 | 12:47 PM
ohnoesaz's Avatar
I was putting a "T" in the heat exchanger inlet hose so I could add a fluid cooler in parallel with it, which I did. I guess I expected the temperature guage to read lower after the install but its not, so I haven't bothered sharing any pics with you guys. Maybe I'm just disappointed.
But yeah, I bent down the plastic piece to give me more elbow room. I didn't quite put it back how it should've been, didn't seem important as I was planning to get back under there after a test drive. When I went for a drive, someway, somehow, the plastic piece touch the road and tore off from the rest of the plastic piece, so I'm missing that corner bottom piece, but still have the part that wraps up around the tire.
Its possible the wind bent it down while driving...
Old Jul 20, 2010 | 04:29 PM
Kit Fox's Avatar
I'll bite, 60191. Need it after mine got ripped up recently for some reason...
Old Jul 20, 2010 | 06:38 PM
Buggin's Avatar
I got an aftermarket one for my SLK32 from iautobodyparts.com for $21 +s/h. I wonder how different yours is? The only difference in the aftermarket one was that the "door" was a pop-in piece instead...
Old Jul 22, 2010 | 11:52 AM
Kit Fox's Avatar
Got a pic of it or schematic? I'm curious if it's the same.
4drturbo
Jan 3, 2019 02:46 PM
BrenLW
Aug 5, 2015 04:53 AM
SuperD500
Jul 23, 2015 02:53 PM
mike28117
Jul 10, 2015 10:51 AM
2005 Ragtop
Jul 9, 2015 03:16 PM
