Intercooler pump fuse keeps blowing.
Old Dec 11, 2008 | 09:37 AM
robby363's Avatar
Default Intercooler pump fuse keeps blowing.
I replaced the pump back in April with the Johnson pump and the car has been running great. But for the past month now the fuse keeps blowing out. I checked the wire connections and they seem to be ok. The only thing I can think of that might be the problem is if motor is getting wet or moisture in it. Has anyone had the same problem or any idea what the problem might be?
Old Dec 11, 2008 | 10:31 AM
waldig's Avatar
Default Re: Intercooler pump fuse keeps blowing.
I would look at the socket, if the pins are loose the terminals will heat up and even normal current levels will melt the fuse material.
Look at the fuse and see if the fuse is melted of smokey blown. Smokey looking plastic is a high current overload and indicative of a shorted connection or a commutator that is having problems in the pump motor.
In the short term, you could replace a higher amperage fuse, upping it no more than about 5 amps once to see if that is sufficient or if the problem is more than that.
If you wanna unplug your pump and install a fuse and drive around for a while, youll know it there is a short. With the pump unplugged the fuse should NEVER blow/melt, just as a hint.
BTW my Johnson pump is still ok on the stock fuse..........ENJOY
W DY
Old Dec 11, 2008 | 10:42 AM
robby363's Avatar
W DY
Thanks, I was thinking about trying a 15 amp fuse. If the wires aren't wrapped good with tape around the connections could that be the cause if they are getting wet? I think it might be the pump itself because it has worked fine for 8+ months.
Old Dec 11, 2008 | 11:01 AM
waldig's Avatar
Water has no effect, especially for 12 volts. - - - High tension lines get rained on daily - - -
Water and 12 volts do cause corrosion to eat and errode the connectors of wiring and that usually causes them to stop operation, drawing less current, not more...........
Woody Enjoy
Old Dec 11, 2008 | 11:34 AM
tighed1's Avatar
You did solder your connections didn't you?
Did you tie down the wires so they don't rub on anything? Could be a short to ground if the wire has rubbed through the insulation somewhere.
Old Dec 11, 2008 | 11:55 AM
robby363's Avatar
I didn't solder them I used insulated male and female connectors that you crimp. Then wrapped them with electrical tape.
Old Dec 11, 2008 | 01:51 PM
MikeR's Avatar
Robby, you should solder them and use shrink tubing to cover. When I did mine two weeks ago, I soldered them, covered with silicon and then shrink tubing over that to keep any moisture out.
MikeR
Old Dec 11, 2008 | 02:27 PM
ACRucrazy's Avatar
Poor connection = loss in voltage. Loss in voltage = increase in amperage.
Increase amperage too much and POP!
Old Dec 11, 2008 | 04:23 PM
waldig's Avatar
Talking Re: Intercooler pump fuse keeps blowing.
Gotta disagree with that one. Current is voltage divided by resistance , thus lower voltage is lower current.
Cars dont have negative resistance loads, so when the voltage is diminished the load current falls, period. Inductive (A/C)motors would exibit negative current characteristics when they enter the stall region of their operational curves. Luckly we have no inductive motors, only brushed DC or Brushless stepper motors.
Enjoy Woody
I = E (v) / R and Power P = E(squared) / R [R = resistance]
Old Dec 11, 2008 | 04:34 PM
It would be nice if you could borrow an inductive DC Amp meter and measure exactly what the pump is drawing. Some and most Multimeters will measure up to 20 amps DC.
To eliminate any other wiring issues, connect it directly to the battery while testing with an amp meter.
James
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
