U-Joints Cost $1,800??...Holy Cow!!!
I have a pulsating vibration in my car when I get above 60mph. It shake the entire car, not just the steering, is present when cruising, and not so much when accelerating. I already had the tires balanced, so it appears to possibly be the U-Joints, as suggested by PaulW.
Here is my main question...My dealer just said that they haven't checked to see if that is problem yet, but that it would be $1800 to replace my U-Joints! WTH! That sounds EXTREMELY high to me. Anyone have any knowledge in this area of these cars?
I have replaced entire driveshafts before, and they are only a few hundred dollars. Though be it they were not on crossfires.
You sure it's not the carrier bearing? Needswings changed his and don't remember how much but thought it was around 200 bucks. I don't think our ujoints would fail before the carrier bearing.
https://www.crossfireforum.org/forum...arrier+bearing
http://www.needswings.com/ProductDet...?productID=623
007, is there a drive train shop in Brenham ? 1800 bucks is out-freakin-rageous !
May wanna contact these folks to see if they can help, I don't know what you guys have down in Brenham.
Good luck !
www.austindrivetrain.com/
Good luck !
Obviously, I grew up on American V8's, so this type of 'shaft' is different to me.
They are telling me it is a special shaft, not a driveshaft, and that it doesn't have u-joints.Dealer says $1600 for new shaft and $180 to install...
ya they come at a whole unit, no u joint you get the axle also..
http://www.chryslerpartsdirect.com/
Axle assy, crossfire 05-06 $972.00 $787.32
rear axle shaft 3-400
SHAFT, Axle Half 05140893AB Figure 3-410
check with Rob @ needswings
Good luck !
Good luck !
Originally Posted by waldig
Ill do it for $1611 if your near Va. Use a dealer as a reference ONLY. Woody
Needswings is most likely my next step. For some reason those threads didn't show up on my search
. Thanks for all the responses!
If it is the ujoint the driveline part number is 5135420AA and it is lots cheaper, I have sent you a PM on the price. By the way the Mercedes part number is A 170 410 28 06 , just FYI.
If it is a rear axle the part number is 5159990AA and the MB # is A170 410 28 06.
You could take it to a driveline shop and they could probably repair it cheaper like Stogey said. Make sure you tell them it is a SRT, there are three drivelines one for the auto trans N/A - one for the manual N/A and one for the SRT.
here is the thread to the drive line thump by Rob @NW
https://www.crossfireforum.org/forum...ighlight=thump
Item NumberMSRPCore PricePrice5135420AA $1,290.00$0.00$1,044.90Universals & rear axle - Rear axle - Propeller shaft - Drive shaft
Drive shaft, crossfire, w/supercharger 2005 - 2006
Add to Cart Contact Us OEM Catalog Item NumberMSRPCore PricePrice5135420AA$1,290.00$0.00$1,044.90
SHAFT DRIVE
SHAFT DRIVE
The driveshaft is similar to my old 88 300zx and the entire assembly has to be replaced. I took mine out and went to a driveline shop and they made me a new aluminum one WITH changeable U-joints for $200.
Ok, kinda overwhelmed here. It could be the carrier bearing, shaft, end blocks, axles, pinion bearing...etc.
Anybody have an opinion on this based on my problem? Thinking about replacing the carrier bearing first and seeing how that goes....Also thinking about just going to a shop to get a custom one, but it is my daily driver....
Rob @ NEEDSWINGS solved his issue with carrier bearing..
i have thump sometimes when i launch also
Well, after some personal inspection of the drive shaft I became convinced there were no problems there, so i went back to the tires. BINGO! Four new tires and problem solved....*#&$& Dodge tech....
Originally Posted by 240M3SRT
Wow glad to see you didnt waste $. What dealership was this?
Tires solved my pulsating issues. My issue didn't start until around 75 to 80 MPH. it was almost like a rolling pulsation. Like surround sound, going from the front to the back of the car.
My tires where worn at the edges but still had some good tread in the center. I had a tough inspection station that wouldn't pass them and I went and replaced them. Pulsating problem was gone!
