Drag Slicks
Old Jan 3, 2009 | 01:29 PM
mitts69's Avatar
Default Drag Slicks
Has anyone set up their SRT6 with drag slicks ? What wheel did you use and where did you find "slicks" to fit up ? Also, has anyone tried a smaller wheel and tire to shorten up the gear ratio for quicker times. Thanks
Dave M
Old Jan 3, 2009 | 01:42 PM
j-fire's Avatar
Default Re: Drag Slicks
ive seen people using 17" mercedes e-class wheels since it's hard to find our bolt pattern in a smaller diameter wheel. likely you can find some mercedes 'replica' wheels on ebay if you want to spend less.
Old Jan 3, 2009 | 01:51 PM
Mimi05SRT6's Avatar
I've had success with the 17" VOXX MG's w/20 offset and short bolts from Discount Tires for $131 a piece. And for the exact height as our stockers, I have the 275/40-17 Nitto drag radials that I got for $155 a piece from Firestone. Shorter size will probably cause you car to spin even more and lower your trap speed. Good luck..
Old Jan 3, 2009 | 01:59 PM
RIOT's Avatar
Discount tire.....
I used VOXX rims Mickey Thompson ET Streets
Old Jan 3, 2009 | 02:29 PM
cruzinquick's Avatar
go to tiredirect.com and use the tire size calculator. Use the combo that is the closest to stock as possible. I run 16" E500 wheels with a 255/50-16 hoosiers which you will find is very close. No low mph here. 117mph in the 1/4 is not to shabby. Now your asking about drag slicks not drag radials. The only drag slick available is from Mickey Thompson and is a bias tire, not radial. It's a 16" by the way. You probably want to stay with a radial. If you search discount for 5x112 by the rim size you are looking for quite a few will pop up.
Old Jan 3, 2009 | 02:33 PM
http://www.voxxwheel.com/wheels/voxx/missano.html this is the ones i found and they are 17 x 9 this vender we have had just the two because the 17 X 9 was discontuned about a year ago. I have 275 40 x 17 but 9" wide
I also have these http://cgi.ebay.com/ebaymotors/ws/eB...m=200293125008
Old Jan 3, 2009 | 02:35 PM
Moparrbust's Avatar
I use Hoosier 315/35 17 Drag Radials mounted on Voxx 17x9 rims.
Old Jan 3, 2009 | 03:38 PM
SRTpowa's Avatar
Well I got tired of rolling on miss matched wheels, so I found a set of matching 18's. They are made by ADR 18x8.5 35mmET and 18x9.5 25mmET. Sold my VOXX wheels and Hoosiers. I will be running Mickey Thompson ET Street radials, 265/40/18. I would have had everything on this weekend but a shipping mixup shot that down, so maybe next weekend.
Old Jan 3, 2009 | 05:26 PM
240M3SRT's Avatar
Hey Mopar do you run spacers if so how thick and whats the wheel offset?
Do the tires ever get close to rubbing the 1/4 panel edge or the inner frame?
Old Jan 3, 2009 | 05:30 PM
Moparrbust's Avatar
I use 15mm hubcentric spacers which brings the rims to the exact same offset as OEM and allows me to use the same lug bolts. I cannot remember if the offset is 20mm or 40mm off hand. The tires BARELY rub the undercoating on the inner wheelhouse if I max out the suspension travel(ie going over speedbumps too fast) but other than that there's no issues.
Old Jan 3, 2009 | 05:43 PM
Mimi05SRT6's Avatar
I bet those 315's really hook up a lot better than the 275's you once used. What '60 difference have you seen with them?
Old Jan 3, 2009 | 06:03 PM
Moparrbust's Avatar
Minimal so far but I have yet to REALLY put them to proper use. There have/had been no real track nights..........other than open ricer nights with NO prep to run on this past year since getting these tires. I will hopefully have some nice 60's to speak of by the end of this month since there's 2 or 3 big events which will be nicely prepped.
Old Jan 3, 2009 | 11:06 PM
SRTpowa's Avatar
Personally I don't see how a wider tire would help or be better. I figure if Lethal Performance can run low 10's in their GT500 on the same 265 tire I am going with, they should do just fine. Hell my 275 hoosiers were bad ***, but a 315 definetly looks better.
Old Jan 4, 2009 | 07:24 AM
mrphotoman's Avatar
What 60' times do you drag radial guys get consistently? I have some 1.8's and others like distantpulse are getting 1.7's on street tires. It would take consistant 1.5's or so before I would spend the money. I ran drag radials on a extra set of tires on my last car and it was an aggravation swapping the wheels back and forth all the time.
The setups you guys have look nice though, I think the 16" wheel would be best since you get more sidewall on the tire and that usually equals more traction at the track.
Old Jan 4, 2009 | 02:54 PM
Mine are usually 1.7's. I'm hoping for 1.6's at Famoso. We'll see.
Old Jan 5, 2009 | 02:34 PM
Mimi05SRT6's Avatar
When the track is prepped correctly, I'm pulling 1.7's.
tom2112
Dec 1, 2015 09:02 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Ralph289
Sep 21, 2015 09:34 PM
tom2112
Jul 28, 2015 08:12 AM
grip grip
Jul 4, 2015 12:36 AM
