Stealership says S/C clutch not IC Pump???
Old Jan 29, 2009 | 11:03 PM
PA/XFIRE's Avatar
Default Re: Stealership says S/C clutch not IC Pump???
I AGREE WITH WOODY. [quote] CRAPPY CONNECTION SOMEWHERE.[UNQUOTE] LOOSE CONNECTION = INTERMITTANT OPERATION,ALSO HIGH OHM READINGS ACROSS COIL OF S/C CLUTCH.PARDON THE COLOR. GOOD
LUCK WITH THE REPAIR. ILLCYA
Old Jan 31, 2009 | 12:15 AM
Brent's Avatar
My dealer replaced my supercharger assembly due to a bad clutch and my service adviser mentioned that the unit cost $7000. It was under warranty so I wasn't concerned about the cost. Replacing the supercharger turned out to be a four day job, though.
Old Jan 31, 2009 | 08:55 AM
Goldwing's Avatar
Now that my SRT6 is almost out of warranty, I guess I'll say a prayer every night that my s/c does not fail. I don't have an extra $7k laying around and don't believe in extended warranties.
Old Jan 31, 2009 | 01:33 PM
Jesda's Avatar
Reman is only $1495, which isn't unreasonable to me if you have a reputable shop willing to do the job.
Old Feb 1, 2009 | 11:39 PM
Gramma_Benz's Avatar
Will this work for you?
http://tampa.craigslist.org/pnl/pts/982301869.html
Old Feb 8, 2009 | 06:51 PM
tighed1's Avatar
Originally Posted by waldig
200,000 ohms means that the windings are not correct, there is a break in the path and that the coil (appears to be) defective. I would expect that the reisistance off of my head should be less than 50 ohms or less dwn to about maybe 8 ohms or so.
Measured my coil today and I got 4.2 ohms.
Old Feb 9, 2009 | 03:06 PM
Jesda's Avatar
I found the notes on the writeup amusing:
PROBLEM: "CUST STATES CORRODED HARNESS, WATER INTRUSION IN LOCK MODULE, ACCORDING TO PREVIOUS DEALER"
SOLUTION: "LOCK MODULE SUBMERGED IN ICE"
Diagnostic fee: $55 (originally $85 before I got pissed)
That's right, I got charged $55 for them to tell me what I told them, that the wire harness was corroded and the lock module was subjected to water. Morons.
In addition, it took then ten minutes to get my car out. I stood outside where they said it would come around. It started raining. I kept asking around and complaining loudly. I even asked a service writer, "Did you guys get lost?" She assured me that it was in the back and would take time.
FINALLY they brought it around. The kid told me it was parked behind a car that was dead, so they had to push the dead car out of the way. I -told- them I was picking it up Monday afternoon!
On top of that, they claimed to not be able to hear the diff whine or the engine ticking, and Greg the service writer got WHINY when I questioned his diagnosis and asked for his technician's Crossfire certifications.
His exact words: "What, you don't believe me?"
[No, I don't believe you.]
Current list of problems at 30,000 miles:
Broken power locks
Corroded wire harness
Engine ticking
Rear water leak
Faulty supercharger clutch / intercooler pump
Oil leak
Broken heated seats
Differential whine
Still starts and runs.
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
