30000 mile service
Old Feb 9, 2009 | 09:58 AM
cassidyrj1's Avatar
Default 30000 mile service
I just brought my car in the to dealer at 7:30 am and i need my 30000 mile service i am just wondering what other people have paid for this. They told me it was going to be 800.
Old Feb 9, 2009 | 10:10 AM
rodimus's Avatar
Default Re: 30000 mile service
What are they doing exactly?
Old Feb 9, 2009 | 10:28 AM
maxcichon's Avatar
These cars have "A" service and "B" service. At 30K, you might be calling for a "B". Do you see 2 little wrenches in your dash?
Last week I was sitting at the dealership and noticed they had Chrysler services set up in mileage increments. I'm not sure that applies to our cars. Do you have an Owners Manual? The Maint. schedules are on page 247+.
SCOPE OF WORK FOR “B” SCHEDULE
MAINTENANCE SERVICE
Oil Change
Change oil and replace filter
Maintenance
Rotate tires
Replace dust filter
Lubricate hood hinges, latch, and secondary latch
Reset FSS Display
Function Check
Horn, hazard warning flashers, turn signals, and indicator
lamps
Headlamps and exterior lighting
Windshield wipers and washer system
Check seat belts for damage and proper function
Test hydraulic brakes and check parking brake function
Inspection
Check front and rear brake pads for lining thickness
Check condition of front and rear brake discs
Check tires for damage and general condition
Check tire inflation pressures and correct if necessary
Check major underbody components for leakage or
damage (if there are signs of leakage, determine cause
and repair)
Check condition of front axle ball joints and rubber
boots
Check condition of steering components and rubber
boots
Check underhood components for leakage or damage
(if there are signs of leakage determine cause and
repair)
Check condition of accessory drive belt
Check headlamp aiming, adjust if necessary
Check windshield wiper blades, replace if necessary
MAINTENANCE SCHEDULES 251
These cars have an "A" service or a "B" service. At 30K, it might call for a "B
Old Feb 9, 2009 | 10:30 AM
maxcichon's Avatar
And here's the "A" list:
Your Flexible Service System (FSS) — see Understanding
Your Instrument Panel section — should give you an
exact indication of when your vehicle should be scheduled
for service and which schedule to follow.
Additional Periodic Maintenance
items should also be
performed beyond the items listed in the following charts
to assure the optimum performance of your Crossfire.
SCOPE OF WORK FOR “A” SCHEDULE
MAINTENANCE SERVICE
Oil Change
Maintenance
Reset FSS Display
Function Check
lamps
Inspection
Fluid Levels
Check fluid levels for the following systems and correct if
necessary. Should there be a loss of fluid that cannot be
explained by regular use, trace and eliminate the cause.
Engine cooling system (check corrosion inhibitor/
antifreeze)
Hydraulic brake system
Power steering system
Windshield washer system
250 MAINTENANCE SCHEDULES
Old Feb 9, 2009 | 10:35 AM
smithy's Avatar
So, the B service calls for the grease monkey to rotate the tyes, eh? That will be interesting with different size wheels on each axle! The poor car would go down the road like a crab!
cruzinquick's Avatar
Sounds like $800 of stuff the quick lube does on a 21 point inspection. Prepare yourself for estimates on all the parts that are not covered under warranty. Belt, brakes, fluids, maybe even take a shot at your tires separating.
Old Feb 9, 2009 | 10:48 AM
REVIT93RX7's Avatar
There is no special service for 30K miles. Ask the service rep to show you where a special service is required.
Old Feb 9, 2009 | 10:54 AM
cassidyrj1's Avatar
I'm not sure what they are doing but they said it was going to be 800 and i asked if there was going to be any hidden fees or anything. He said no. So i told him if they do need to replace anything to call me first other wise they would be paying for whatever they didn't tell me about. I has this in writing to so I'm not to worried about any hidden things.
Old Feb 9, 2009 | 10:57 AM
msheredy's Avatar
So $800.00 for an oil change because that is all that they are going to be doing. Dude get yourself an oil extractor and change it yourself and save a boat load of dough!
Old Feb 9, 2009 | 11:10 AM
cassidyrj1's Avatar
MAINTENANCE SERVICE
Oil Change
Maintenance
Rotate tires
Replace dust filter
Reset FSS Display
Function Check
lamps
Inspection
and repair)
boots
boots
repair)
I only saw one big wrench but to me what he was talking about any looking at the two services is sounds like he is going to do both service a and b
Hoppy
Dec 7, 2018 07:36 AM
spoiler
Sep 2, 2015 08:56 PM
MAXIMUM
Aug 4, 2015 11:04 PM
axnguyen
Jul 21, 2015 11:41 AM
Rusty475
Jul 13, 2015 10:03 AM
