Throttle Body flow bench test
Old Apr 29, 2009 | 12:41 PM
Bulldogger's Avatar
Default Throttle Body flow bench test
Has anybody flow tested our throttle bodies. With the consistant 380 whp on heavily modded cars regarless of 178/181/185 pulleys, I believe we have a bottle neck. Now if you use nitrous you go over that 380whp mark because you are introducing oxygen into the motor through a means other then the throttle body sucking it in. I think if we can get a bigger throttle body it will help us in the quest for 400+ whp. Does anyone have a spare or know where I can get one cheap, I may try to see if I can bore it and remake the butterfly for testing puposes. Thanks
Old Apr 29, 2009 | 01:15 PM
Jeff Cobb's Avatar
Default Re: Throttle Body flow bench test
Check with TVT or NeedsWings.
TVT offers a 74mm throttle body: http://tvtdesign.com/inc/sdetail/1344
NW has intake mani's & Y-pipe:
http://www.needswings.com/Products.a...1-885537264510
Also, check out this thread:
https://www.crossfireforum.org/forum...ad.php?t=32672
rampntlion
21
Feb 11, 2019 08:18 AM
cjw
Oct 26, 2015 10:26 PM
atdavis2
Sep 21, 2015 01:25 PM
tritongreen
Sep 18, 2015 07:32 AM
steps
Sep 3, 2015 07:24 PM
