Lowering SRT Roadster
Old May 2, 2009 | 03:51 PM
gr8len's Avatar
Default Lowering SRT Roadster
Guys,
I'm looking to lower my roadster and would like to get some opinions/options on the best method to do so. I know the srt roadster has different suspension dynamics than the coupe and there have been numerous discussion on the board but not much focus on the roadster so I'd like to hear from you roadster owners who've lowered their cars. I'd like to retain or improve the ride quality, if possible, and do it at a reasonable cost.
Thanks for your help!!
Old May 2, 2009 | 03:58 PM
Default Re: Lowering SRT Roadster
Check with RPM. He should be able to share his concerns with the lowering of the SRT Roadster.
Old May 2, 2009 | 06:22 PM
cgocifer's Avatar
Not a roadster, but I lowered with Eibach springs and Koni adjustable shocks. Well worth the cost! I believe the part numbers are the same for both the coupe and roadster.
Old May 2, 2009 | 06:29 PM
j-fire's Avatar
wrong.
you HAVE to order a kit SPECIFICALLY for the Roadster.
make sure you see this when you order your parts.
Roadster lowering kit is not the same as the coupes. the Roadster has bracing the coupes don't have.
Old May 2, 2009 | 09:59 PM
bhays's Avatar
Originally Posted by j-fire
wrong.
So what's the part number for the roadster, then. I lowered my roadster, went to tirerack.com and there was only one eibach part for both roadster coupe, base, srt, limited, period. Worked fine. Now I have an SRT roadster on the way and planned to use the same kit.. 2552.140?
Old May 3, 2009 | 12:08 AM
RPM's Avatar
RPM
Moderator
gr8len, I replied to your PM.
From what I understand, the Eibachs that NeedsWings sells, etc. are supposed to work on any Crossfire. I believe the roadster bracing has nothing to do with the springs, you just remove them, install the springs, and reinstall the bracing.
I had the Eibachs on for a day or less. Drove ~10 miles or so and the wheels hit the insides of the wheelwells on every little bump.
Sure, it looked nice, but it was not worth the headache IMO. I would not recommend lowering a SRT6 Roadster.
Old May 3, 2009 | 12:15 AM
bhays's Avatar
That's strange. I never had a problem with the Eibachs on my roadster with stock size wheels and tires... never rubbed once...
Old May 3, 2009 | 12:49 AM
j-fire's Avatar
here's what heard from eibach dealer: roadster is heavier, therefore springs may 'sag' if you do not use the roadster-specific springs.
Old May 3, 2009 | 01:01 AM
bhays's Avatar
Thing is, if you go directly to Eibach's site or to a dealer, there do not appear to be any 'roadster specific' springs... they show one part number for all Crossfires period.
Old May 3, 2009 | 09:29 AM
MisterTaz's Avatar
Guys,
I don't know about Eibach; I didn't go that way. I went with HR Sports and their site definitely says there is a difference between the Coupe and the Roadster. HR lists the Crossfire Coupe Part # 50805 and 50869 for the Roadster.
Like I said I went this way because I had good luck with HR in the past and they drop the car a bit lower. I did have to add a KMAC kit to get the camber correct in the rear.
I hope this helps. Stay safe...
Respectfully,
Paul (MisterTaz)
Old May 3, 2009 | 11:21 AM
ACRucrazy's Avatar
Wink Re: Lowering SRT Roadster
The roadster weighs all of 88 pounds more than the coupe. but has better weight distribution. The weight difference between driver A and driver B could be more than 88 pounds. Hell some peoples stereo's weigh more than that.
As far as SRT stating the Roadster and Coupe have specific spring rates for each car stock. I believe it, however I doubt its enough to make a difference and have yet to see what those rates are published anywhere.
If aftermarket company A makes 2 sets of springs for the SRT, one for the Roadster one for the Coupe, great.
If aftermarket company B makes 1 set that for the SRT, I am sure that will be just fine also.
88 lbs wont make one SRT sag more than another on a street car to matter because of spring rates. If it does make that big of a difference to the driver the dealer offers several different spring pads for someone to fine tune their suspension. Then again someone who is really that concerned about having a fine tuned suspension for racing wont run progressive springs.
Hell, the difference between a full tank of gas and empty tank is more than 88 lbs.
Ok I am done
Old May 3, 2009 | 11:28 AM
and there you have it....really they prolly braced the ' vert to be a little overkill as well. Our German friends like to engineer the h*ll out of things, which is good, but I think you will be fine which ever way you go...good luck, now I am not lowering mine, because since I retired from active duty, and now a reserve, and second, driving a truck, eating truck stop food, I think mine will lower itself in due time....
Old May 4, 2009 | 12:31 PM
gr8len's Avatar
Thanks for all of your replies so far! Does anyone know if there are other springs besides Eibach or HR available for our cars? I believe I ran into a set on ebay in the past but could not locate them again. BTW, do we have the same springs as the SLK32?
Thanks again guys!
Old May 4, 2009 | 12:55 PM
MisterTaz's Avatar
I believe that psuperti runs on Intrax springs
I hope that helps.
Stay safe...
Respectfully,
Paul (MisterTaz)
Old May 4, 2009 | 01:10 PM
j-fire's Avatar
Eurocharged sells 'Roadster specific' springs by ST (Sport Tech)
H&R also sells 'Roadster-specific' springs as well.
i can't tell you exactly WHY there's a difference, but if it was my SRT6 roadster, i would only purchase 'Roadster-specific' springs.
just my opinion, do what you want.
link to springs(scroll down to near bottom of page): http://www.eurocharged.com/shop/prod...6&category=all
RED DOG
Jul 21, 2015 07:58 AM
leaddog2015
Jul 13, 2015 12:25 PM
tom2112
Jul 12, 2015 04:41 PM
bradleykologek
Jul 6, 2015 02:49 PM
pop49
Australia
Jul 6, 2015 10:10 AM
