Safe to drive in the rain with a NW CAI?
Old May 6, 2009 | 02:49 PM
cross><hair's Avatar
Default Safe to drive in the rain with a NW CAI?
I'm not talking about trudging through tall puddles but I imagine a good deal of moisture will get past the front grill and to the filter element of the CAI. Is it safe?
Old May 6, 2009 | 03:22 PM
mrphotoman's Avatar
Default Re: Safe to drive in the rain with a NW CAI?
i had them make me a hydro-shield for mine back when i bought it for extra protection against hydrolock. I got the first one ever made
it works really well but to be honest i forgot to put it back on last october when i was at maryland and have been running it fine without it ever since.
Old May 6, 2009 | 03:24 PM
Stogey's Avatar
One of our CTC members stuffed his behind the right side fog lamp assy. Not exactly in the air stream but it is "cold air" ! I plan on doin the same with mine when I get it mounted up.
Old May 6, 2009 | 03:44 PM
bombsquad56's Avatar
No problems with ours even though it rains often here in Florida. You can always add the waterproof cover to your filter, Needswings sells them. Our grill is modified which exposes the filter even more but still no problems.
Old May 6, 2009 | 03:59 PM
BrianBrave's Avatar
<--- Huge Horsepower
You have to put a sock over your intake when it rains?? Does the water damage the filter?
What happens if you head out and you forget to take your sock with you, and it starts raining?
Do you have to take the grill off to put the sock on?
Old May 6, 2009 | 04:04 PM
mrphotoman's Avatar
it goes over the filter and stays on the filter all the time. there is very little if any restriction. it just replels water, not air. there would be no reason to take it off unless you want to make sure you got that extra 1/10'th whp at the track.
Old May 6, 2009 | 04:07 PM
///SilverSaphRT6's Avatar
K & N's are oil lubricated(red oil) for this purpose....
Old May 6, 2009 | 04:13 PM
waldig's Avatar
Talking Re: Safe to drive in the rain with a NW CAI?
I installed both of them on an angle to prevent any issue and drove 1000 miles to the dragon in the rain. Enjoy, Woody
Old May 6, 2009 | 06:11 PM
msheredy's Avatar
No problems what's so ever.
Old May 6, 2009 | 06:14 PM
apkano's Avatar
Life is random...so am I.
I've had mine on for almost 2 years without a problem.....EVER.
I don't think so.
Old May 6, 2009 | 06:20 PM
robby363's Avatar
I've put over 15,000 miles on mine in the rain and snow and have had no problems.
Old May 6, 2009 | 06:32 PM
You are unlikely to get Hydro lock with a CAI. what you may get is interference wth the MAS. Any water that gets past the filter element will be mist and will effect the MAS as the fluid acts different than the air.
My unit from Eurocharged is in the fender well where the IC pump is located on SRT's. It had issues in heavy rain as the vertical piping would develope a water bubble. I put a plastic garden drain grill under the filter element and have had no issues since.
My deluge thru Nashville where, at 60 MPH, I ran thru a puddle over my axles proved the system is safe from hydro lock. The water tore the access door off but the engine ran fine. I imagine to get hydro lock you would need at least a 50% volume/ratio of water to air. In other words a solid wave of water. The NW are high enough, this is unlikely. But the socks work well and would prevent it.
If you do get a MAS interference issue, it would be during high acceleration. The the worst you might see is an engine light and rough running. Shut down, disconect the battery for a few seconds and it will right itself.
My experience anyway.
roadster with a stick
Old May 6, 2009 | 06:33 PM
32krazy!'s Avatar
waldig i see you have a dual cai. i dont see it on needswings website. is it still available or did you build it?
Old May 6, 2009 | 07:14 PM
I ran mine in the rain all way to the dragon, and back....no issues at all...
Old May 6, 2009 | 08:16 PM
waldig's Avatar
SLK32 I built mine, Rob is now introducing them, there is another post showing the kit "in christmas", Enjoy, Woody
Old May 6, 2009 | 08:22 PM
32krazy!'s Avatar
just saw the posting. i just wish it didnt cost my firstborn!
Old May 6, 2009 | 08:27 PM
mrphotoman's Avatar
I don't think so.
just like i said, i do have the first one made, call him and ask. he had to have it special made for me when i bought the intake.
Here you go, the original pm. Let me know if I can help you with anything else:
ill make at least the intake happen for ya buy then, if the cover is a few days behind it will be a 3 minute job to add it on after the intake is already installed. thanks, rob
thanks for going the extra mile on the drycharger. if you think it can all ship out and i can have it by friday 18th that is fine. i have a track day the following weekend so i would need the weekend of the 18th to install and test everything.
thanks again,
tim
ok, just giot off the phone with k&n, they referred me to the company that makes the out covers for them, i spoke with them and they are making a custom tailored drycharger cover for you, it will be $21 and they say it will take them a week to make, look slike we just hit 30 for the group buy so the refund for the 30+ we can just put towards the drycharger so you should be all set, assuming the intakes are finished before the drycharger arrives do you want me to wait and send them togather? thanks, rob
Old May 6, 2009 | 08:39 PM
Punkin's Avatar
I have a dual CAI using Needswing design and have put 30k miles in daily driving with out an issue. I don't think you will have an issue.
Old May 6, 2009 | 09:23 PM
downwardspiral's Avatar
There was an old, nasty K&N panel filter on display where I work.. I tried cleaning it with water one day just to make it presentable, and I literally filled it up with water and nothing leaked through. I haven't worried about the intake since.
Old May 6, 2009 | 09:35 PM
apkano's Avatar
I thought you were talking about the topic of the thread.....the intake itself. Smarta$$.
