Methanol/water injection
Old May 16, 2009 | 11:02 PM
mikenewb's Avatar
Default Methanol/water injection
Anybody ever thought of doing this to our SRT's for cooling? Sounds like might be neat idea!
Snow Performance: Products
Old May 17, 2009 | 09:52 AM
Default Re: Methanol/water injection
do a serch a few have done it mine is in the box just putting on paper how i want it ,, but yes , it works
being we have no place to put the container i am looking at putting it under the front bumper.
Old May 18, 2009 | 01:58 AM
Redriot's Avatar
Tanks: take a walk through your local salvage yard (if they will let you) look under as many hoods as you can to get an idea whats out there. The oldest vehicles have some of the better shaped tanks. Look for one that may fit the void you want to stuff it in. Having a measuring tape with you mat be helpful. When you find one, inspect it for crazing (fine cracks but not broken through) If there is excessive crazing don't get it it will break easily. Look for signs of UV degradation as this type of plastic doesn't like sunlight. Milk white, barely translucent, with a semi gloss skin is good but grayish white with a matt finish is bad, don't use the later. Any tank that may have sloshing fluids should have as much support as possible. My tank is a two gallon and came out from under the hood of a late eighties chevy pickup. It now resides in the left well under the hatch deck floor, The battery is on the right. the pump is next to the tank. Hose routes to the right then forward. Good Luck!
Old May 18, 2009 | 08:43 AM
distantpulse's Avatar
Here are a couple of pics of my setup........I have the AEM kit with a dual nozzle setup that runs into each intake manifold. Rob from Needswings did an excellent job with this little project of mine. I am really happy with the way it turned out! Now I just need the car tuned to run with the added water/meth. BTW, I do run a 50/50 mix of straight meth/alky and water.
Installed in car......
Tank mounted in trunk....
Old May 18, 2009 | 08:50 AM
How do you get to your tank easy?!
Old May 18, 2009 | 09:35 AM
waldig's Avatar
Talking Re: Methanol/water injection
In my opinion thoes injectors are at the correct spot if not ideal. Should never be in the s/c or before the i/c or the benefits are lost.Woody well done all.
Old May 18, 2009 | 10:02 AM
Tamadx's Avatar
in all technicality in meth setups it should be about 8-10 inches from the TB. so this looks like a nice setup.
in my Neon i had it right before my temp sensor so it would increase my timing also.
Old May 18, 2009 | 01:56 PM
BlUEMDsrt6's Avatar
Do you think moving the IAC sensor into the manifold (like BDJ did) would yield a better result since it would register the cooling effect of the meth?
Old May 18, 2009 | 02:52 PM
Tamadx's Avatar
again not sure how these cars would respond but in all reality the meth would trick the comap to to think the intake temps are a lot cooler than they really are thus giving you more timing. with a 50/50 mixture it seems to be safe... with a pure meth mix it would cool just fine but throw your a/f's off becasue the increase in fuel. D/I water is the best for the cooling effect youre looking for thus a lot of people run a 50/50 mix...
for the best COOLING affects minimal meth is needed... like the mixture of a clean bottle of wiper fluid.
to add more ummpf for lack of better words a meth mixture would be nice because of its burning properties.
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
tritongreen
Sep 18, 2015 07:32 AM
crymar
Jul 17, 2015 08:46 AM
Mimi05SRT6
19
May 12, 2013 02:05 AM
ChuckNorris
Jul 2, 2009 10:30 AM
