Modified Dual Intake
Old Feb 18, 2010 | 04:50 PM
waldig's Avatar
Talking Re: Modified Dual Intake
I rebent the tranny lines and flipped them upside down to get them out of the way. Please look at my gallery and see the photos there so that you can see how they were mounted, formed. Woody
Old Feb 18, 2010 | 05:11 PM
goodgenes79's Avatar
Default Re: Modified Dual Intake
I thought of that but wasn't sure tif the lines were able to be rebent without snapping in two.
Old Feb 18, 2010 | 11:57 PM
ProjectMayhem's Avatar
Like woddy said i just bent them out of the way, just be careful not to kink anything. Needswings sells a relocation bracket and what not if you aren't a do it yourselfer type.
About the issue of rain at the filter location. Honestly with the dual intake setup unless both filters get completely blocked by water and your wide open throttle you wont pull in any water. 20,000 miles of the filter in that location with no issues. That includes spray the front bumper/ grill off with the car running to clean off bugs, and driving through a big ol puddle that splashed on the hood. If fact I have no heard of one person Hyrdolocking the motor with a simliar setup.
Edit: also i ditched the Hard merge pipe as it caused to much stress on the throttlebody gasket, while the flat 90degree silicone coupler isn't ideal it does alow for the flex on pipes.
Old Feb 19, 2010 | 10:25 AM
With my Intake, I just used Spectre's y pipe with silicon coupler. I had to shave down the Y to fit between firewall and TB. I like the plastic Spectre uses so that weight is down and temperature desperses equally to aluminum. I will pick up a bender and reverse my PS lines. Thanks
Old Feb 19, 2010 | 02:51 PM
Montana Crossfire's Avatar
I went with the spector y body and shortened it, then ran silicone to throttle body (you can see it in my AVATAR, and while running you can hold the pipes and notice No vibration and very minimal heat transfer.
Old Feb 19, 2010 | 09:16 PM
32krazy!'s Avatar
googenes79 i have the benders and flare tools if you want to use them
Old Feb 21, 2010 | 09:53 AM
I should like to come up and see you, change my tranny oil, and see how your tune and exhaust are behaving.
Old Feb 21, 2010 | 10:37 AM
32krazy!'s Avatar
tune is krazy!! exhaust is were i want it soundwise. havent given up on the true duals but issues there. now that jake is building headers i need to figure a way to get pipes that are 2.5" each into a 4" space!!
thirteendog wants a tranny flush also might as well make a day of it
Old Feb 21, 2010 | 02:35 PM
Just say when
Old Feb 21, 2010 | 04:52 PM
32krazy!'s Avatar
Just say when
pm thirteendog and see when he wants to get dirty again. i wore him out sat doing his brakes!! im open most weekends. as the weather gets warmer we can start earlier. shouldnt take more than a couple hrs to do both. check for the trans sending unit repair while the oil is out
Sep 28, 2015 07:40 PM
Ralph289
Sep 21, 2015 09:34 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
Idrenak
Sep 19, 2015 08:17 PM
RacerXofFL
Sep 15, 2015 05:00 PM
