code 3 instructions
Old Jun 16, 2009 | 01:07 PM
32krazy!'s Avatar
Default code 3 instructions
does anyone have the install instructions for the code 3 pulley? the pdf on the code 3 website wont load. im getting one from a private sale and need to make sure its installed properly
also is there a special tool to hold the oem pulley in place to remove the retaining bolt?
steve
Old Jun 16, 2009 | 01:36 PM
ACRucrazy's Avatar
Default Re: code 3 instructions
steve
I wish I did a step by step with pics on mine as its sooo simple and the instructions from C3 are poor IMO. Extra steps listed in those that simply are not needed.
I went to the local Checker/Oriley autoparts and bouth a 2 piece strap wrench kit for like $10
and you need only reverse torx socket I think? E10?
From memory-
Remove the 2 reverse torx (forgot size, 10?) holding the air pump line clamps. Pull the rubber hoses off from the head, and move 2nd air pump hard lines out of the way. Look at my attached pics. I circled the e-torx bolts.
Unclip the radiator hose (plastic clip)
Take the other reverse torx, put it on the tensioner pulley with a rather long ratchet/breakerbar. Losen tension and remove belt from the SC pulley.
Use ratchet strap hold pulley, remove bolt from SC. (think its a 12mm?) note location of the marking paint. When torqed down (forgot spec, I think 20nm) it should line back up. The bolt is hollow, if over torqued bolt will snap. I believe it was done to prevent you from stripping out SC.
Note how many (if any) Spacers are on the stock SC pulley. Dont lose them.
Old Jun 16, 2009 | 03:39 PM
robby363's Avatar
steve
Here you go.
File Type: pdf
Old Jun 16, 2009 | 06:11 PM
texas t's Avatar
Talking Re: code 3 instructions
Also after removing pulley bolt ,pull straight on washer that has paint on it. MY stock pulley had no spacers but had to use 2 on c3 pulley!
Old Jun 16, 2009 | 06:32 PM
32krazy!'s Avatar
thanx robby! acr i have those strap wrenches and ill pick up a set of reverse torx. YEAH more tools~!!!!
hopefully ill have the pulley by the weekend and can put it on . maybe ill see some decent gains.
Old Jun 16, 2009 | 06:40 PM
ACRucrazy's Avatar
Note, the pics in the code 3 instructions are not of a crossfire.
The directions are not quite the same.
Old Jun 16, 2009 | 06:43 PM
velociabstract's Avatar
About those torx sockets. The instructions are incorrect on the size the tensioner has. It's an
E-10, not an E-11. So all you need are E-10 and E-12 torx, 12mm socket, strap wrench, torque wrench, something for the nerves and away you go. Enjoy the smell of burning rubber!
Les
32krazy!'s Avatar
should be ok as i own a m/b slk32 not a srt-6. i am able to find so much more infom here than any of the m/b forums!! my 32 is big brother of the srt-6 family!
Old Jun 16, 2009 | 06:45 PM
32krazy!'s Avatar
thanx velociabstract. ill just hunt for a set. i have some space left in my toolbox!
Old Jun 16, 2009 | 07:48 PM
PA/XFIRE's Avatar
FYI, The gap between the back of your new pulley and the sc magnetic clutch disc should be between 20 and 30 thousants of an inch. Add a spark plug gapping tool to your tool box if you don't have one. good luck with the install.
ILLCYA
Old Jun 16, 2009 | 07:54 PM
ILLCYA
I measured the stock pulley before the install and it had a clearance of 45 mm. (Isn't it still called a feeler gauge?) My Code 3 has a hair more than 45 mm but it works without issues. I was watching the pulley free wheel the other day at idle. Boy am I easy to entertain!
Les
Old Jun 16, 2009 | 08:25 PM
32krazy!'s Avatar
i have seen numbers from 19 to 45 thousands for a measurement!. anyone know whjat the correct spacing is?
Old Jun 16, 2009 | 08:32 PM
I don't know. The instructions for the first versions of the Code 3 pulley were just as PA / XFIRE stated. The later versions come with no washers or specifications concerning the clearance. But just so you know, mine works great and has .. oooooo .. 47 mm of clearance.
Les
Old Jun 17, 2009 | 01:31 PM
goodgenes79's Avatar
I don't mean to thread jack but I just ordered a Code3 pulley and was wondering how long others had to wait for delievery. I called Code3 but no answer and am anxious to get this on. Also I can't find a thread that describes the difference between shipsets. I am of the understanding that this is the third batch/shipset and that the older ones are considered better. Can someone give me a quick rundown of possible issues with the newer ones? Again sorry for off topic, but I will be using this thread to install
Old Jun 17, 2009 | 01:42 PM
PA/XFIRE's Avatar
Les
Feeler gauge it is.!!!!!!!!!!!
Old Jun 17, 2009 | 01:58 PM
PA/XFIRE's Avatar
Do a search on code 3 pulleys that should bring you up to date, there's been so many differant versions i wouldn't want to give you any wrong information. I
do know that getting an answer from code 3 is a task. if you have any questions after reading the search info pm me and i'll try to answer any questions you might have.Good luck with the new pulley. ILLCYA
Old Jul 4, 2017 | 01:47 PM
Ciel's Avatar
From memory-
any idea where i can get new spacers when i pulled off the pulley 2 of the spacers snaped
usprb1976
Apr 4, 2024 04:57 PM
TOPLESS
Feb 9, 2016 11:28 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
tritongreen
Sep 18, 2015 07:32 AM
MickeyNasty
Sep 6, 2015 08:29 PM
