small battery test
Old Jun 16, 2009 | 05:42 PM
Default small battery test
I have been running this 280 cca small battery for two weeks now as a test,, the cost is under 100. and for under 200. i can get a 600cca.. it weighs 10lbs.. jim
Old Jun 16, 2009 | 06:32 PM
j-fire's Avatar
Default Re: small battery test
do you trickle charge it or anything like that? could you send me a link to this battery? my current one is 17lbs, but has lost charge.
thanks.
Old Jun 16, 2009 | 07:23 PM
I got mine from Rage-tec 954-915-0016 they have this batt in a lot of srt-4's and some srt-8's one in a new challenger i think.. no tickle charger, just the car's charging system
Old Jun 17, 2009 | 11:08 AM
battery can be shipped.
Old Jun 17, 2009 | 11:10 AM
kolevski's Avatar
Wont such a small battery put strain on the altenator? and I'm sure it'l run out alot quicker.
Old Jun 17, 2009 | 11:18 AM
I don't think it makes the alt work any harder ,your car starts on the batt and then it charges the batt and runs the car. they have had a few in srt-4's for over a year,, and found out today there is one in a srt-8 jeep, it has been there for about 6 mo now. jim
Old Jun 17, 2009 | 11:21 AM
kolevski's Avatar
Really? well if it passes in a SRT-8 shouldn't have any problems in our cars, it'l save alot of weight thats fore sure not to mention how much cheaper they are to replace. Good find!!
Old Jun 17, 2009 | 07:26 PM
green-ghost's Avatar
Interested in your results, just wondering how you secure the battery and if you needed to rewire much. At my job Ive access to slightly damaged "employee sales" batteries that are OK, just cant be sold to the public. I get them for 10 bucks and at that price its a mod Id be interested in
Old Jun 17, 2009 | 07:36 PM
i only turned around the negative cable where it is bolted to rhe car that made it long enough so the batt. would sit all the way in the back,,, being it is temp for the test time, i used a square block of strifoam to make up the same size as the factory batt and for now useing the factory hold down. I also have a volt meter that u plug into the lighter and it tells me the volts of the batt,, so far i have 29 starts 200 miles and of the 200 5 have been with the head ligjts on,, so far so good. jim
Old Jun 17, 2009 | 07:47 PM
j-fire's Avatar
can't find it.
link please
Old Jun 17, 2009 | 08:06 PM
Originally Posted by j-fire
can't find it.
link please
Rage Technologies - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
954-915-0016 also www.rage-tec.com tell them you are interested in the batt. with jim's discount for a crossfire. I think it will be 99.00 + shipping jim
Old Jun 17, 2009 | 11:53 PM
ProjectMayhem's Avatar
Nice how much weight are you saving?
Old Jun 18, 2009 | 12:23 AM
Rutten16's Avatar
thanks for the mini review!
Old Jun 18, 2009 | 09:13 AM
I am saving about 35 lbs with this batt.. the only concern is (for some of you not me ) the winter, will it work in cold weather? here in Ft. Lauderdale i don't have cold weather, and if i did i would move south, your thoughts on it working in cold weather? jim
Old Jun 18, 2009 | 12:22 PM
i wouldn't use that battery in the winter up here, would go back to the stock one. Wonder if it could handle 3-4 starts while i go down the staging lanes at the track. I normally have the car off as much as possible while at the track to keep the SC and SC coolant cold.
Old Jun 18, 2009 | 03:00 PM
will be testing the starting 4 to 10 times while moving up in staging line. jim
Old Jun 18, 2009 | 11:58 PM
Nice definately let me know if it holds up. I have been looking for a reliable lightweight battery to run at the track.
Old Jun 19, 2009 | 12:17 AM
SRTpowa's Avatar
I had a DEKA ETX14(Braille) about the same size. Never had any problems unless I let the car sit for more than 2 weeks. Bought a trickle charger and put it on there if the car wasn't driven for a while.
Old Sep 27, 2009 | 01:09 PM
Moparrbust's Avatar
I must be slow because I can't find the battery anywhere in the first link...........and the second one doesn't even work(for me).
Old Sep 27, 2009 | 04:12 PM
ckovach's Avatar
I've been running a Braille in my SLK32 for about 4 months. Not quite as cheap as the Rage Tec battery, but high quality. I didn't go with the ultra-light version (6 lb) because I wanted more amps, but this one is still only 11.5 lb and it works great:
tp://www.tirerack.com/accessories/detail.jsp?ID=28&cat=Batteries
Don't waste your time with the Braille aluminum mount kit, though. It's heavy and way overpriced. i originally ordered it then sent it back. The basic mount that comes with the battery works fine, looks good, and is much lighter. Here's the full line-up of Braille products at Tire Rack:
Tire Rack: Braille
