Unknown Engine Spray
Old Sep 19, 2009 | 06:50 PM
MetalMilitiaSRT's Avatar
Default Unknown Engine Spray
I posted this a month or so ago and was told the liquid is most likely coolant from the top hose, this however, does not seem to be the case. It looks as if it is coming from HERE.(see picture, bottom-right corner) This location correlates to a splatter mark on the hood liner.( see 2nd pic) It only seems to spray or leak when I hit relatively high RPMs. A conservative drive to work yields no spray, yet a quick sprint to the gym and the stuff is everywhere. Are there any additional ideas before I take it to see the doctor?
Old Sep 19, 2009 | 07:59 PM
waldig's Avatar
Talking Re: Unknown Engine Spray
At higher revs the engine needs to breath and the blow-by may be what you see here. I designed the super oil separatorfor this type of crud. Not sure from your picture seems to be from the air injection port, blowby is a possibility. Woody -guessing.
Default Re: Unknown Engine Spray
looks like coolant to me ,, check under your upper hose (bend twistpull it)
close to the fan. jim
Old Sep 19, 2009 | 08:52 PM
RMADERMAN's Avatar
I agree,it looks like coolant. Maybe from the overflow tamk hose.
Old Sep 19, 2009 | 10:47 PM
Rmaderman you forgot to tell him to check the nipple on the collant tank to see if it is cracked. jim
Old Sep 19, 2009 | 11:30 PM
RMADERMAN's Avatar
Yep, check the screw clamp that it is tight and make sure the the nipple coming out of the overflow tank is not cracked or broken.
IGot2P
Jul 26, 2025 12:40 PM
lazorouss
Sep 11, 2015 09:16 AM
BEATv1
Sep 10, 2015 12:58 PM
RiderJC
Sep 7, 2015 11:19 PM
MickeyNasty
Sep 6, 2015 08:29 PM
