Hi Flow Cats
Old Oct 16, 2009 | 06:22 AM
kolevski's Avatar
Default Hi Flow Cats
Has anyone changed there front 2 cats with Hi Flow cats? I want to do it but dont know if it'l confuse the sensors? any input would be great!
Old Oct 16, 2009 | 11:30 PM
ProjectMayhem's Avatar
Default Re: Hi Flow Cats
It will be fine, but keep in mind its only a couple horses you'll pick up at the top of the rpm's i dont know all your mods but its not a very cost effective mod if you looking for more power.
Old Oct 17, 2009 | 03:34 AM
billvp's Avatar
On the twin-turbo Stealth I used to have, I drilled out the precats myself ... so it can be cost-effective ... and that's about as high-flowing as you can get
Old Oct 17, 2009 | 08:15 AM
Buggin's Avatar
Good reading on some independant tests:
Catalytic Converter Removal - Beat the Law - Import Tuner Magazine
Old Oct 17, 2009 | 10:45 AM
cross><hair's Avatar
Originally Posted by Buggin
Those tests were on an NA Honda Civic. Boosted applications will gain MUCH more from lowering backpressure.
Old Oct 17, 2009 | 06:01 PM
32krazy!'s Avatar
there appears to be some decent hi flow cats on ebay for about 75$
Old Oct 18, 2009 | 08:52 AM
kolevski's Avatar
Thanks for all your responses guys!!
My plan is to replace the primary cats with hi flow cats (100cpsi) then to remove the secondary cats and replace it with either an X or Y pipe.
Since I've recently found out that the SRT resenator is infact straight through I'll leave that there.
So essentially I should yield some good HP gains, better throttle response and an all round nicer exhaust note.
Old Oct 18, 2009 | 09:27 AM
MikeR's Avatar
Kolevski,
Getting rid of the resonator will drop about 20 pounds AND improve your exhaust sound.
Old Oct 18, 2009 | 10:09 AM
32krazy!'s Avatar
these cats have gotten some good reviews on the m/bworld forum and they are the chesapest i have seen . hope it helps Thunderbolt High Flow Metalic Catalytic Converter 2.50:eBay Motors (item 370204926271 end time Oct-18-09 12:39:29 PDT)
Old Oct 18, 2009 | 11:27 AM
Do you think these can be used as back cats on the NA? I'm considering removing my back cats, and was wondering if a hi flow cat is the answer.
Old Oct 18, 2009 | 12:07 PM
LantanaTX's Avatar
After getting an up close and personal look at both the 112 V6 and 113 V8 exhaust manifolds it makes sense why exhaust mods don't yield more than a couple of HP's. The stock exhuast manifolds are very restrictive. While getting my exhaust fitted to my V8, I went removed the unmonitored second cats with straight pipe.
Old Oct 18, 2009 | 09:30 PM
kolevski's Avatar
The cats I'm going to use are called Venom they have a metal core and have a heat shield they look very well built, 32krazy those look great but I'm down in Australia might take to long to get them.
Mike removing the resenator will definatly help the exhaust note but I dont think It'l improve hp (as it's straight through) apart from the weight reduction.
Changing up the cats will help the exhaust note and get some hp gains.
I'm doing a dual cai so I'm focusing on helping the car get as much air as it can in and efficently relasing that air without compromising to much of a loss of back pressure (otherwise I'll loose power & torque)
Old Oct 19, 2009 | 08:42 AM
32krazy!'s Avatar
from what i understand the exhaust system should be the last mods that you do because the hp gained is very small compared to the cost involved. headers are needed and are the most expensive running 1000$ and up. the cats and resonaters yield sound inprovement but little hp gains. do a res delete asnd spend the cash for other mods that yield more hp
Old Oct 19, 2009 | 09:45 AM
LantanaTX's Avatar
Here is a site that is making headers and they are actually reasonably priced! $799 for V6 and $1249 for my car. Headers with high flow cats produce some pretty good HP gains.
Abedin Motorsports "Uncompromised Performance"
Old Oct 19, 2009 | 10:31 AM
distantpulse's Avatar
Abedin Motorsports* "Uncompromised Performance"
Did I read their website right? "ECU tuning from home"??! "Software Packages"!?! Could it be!?!
Old Oct 19, 2009 | 11:51 AM
Voyager's Avatar
who is this company? and where have they been
Old Oct 19, 2009 | 12:01 PM
jturkel's Avatar
AMS. They're on mbworld. The guy I speak with on the forum (Omey, i believe he is the owner as well) is pretty nice and knowledgeable about his stuff.
Old Oct 19, 2009 | 12:14 PM
LantanaTX's Avatar
Yes, I found him on MBworld and they seem to like him over there.
Old Oct 19, 2009 | 07:02 PM
kolevski's Avatar
Yeah I've had him in my favourites for nearly a year! the only thing you can get from him is the damn crank pully! never has headers in stock!
Old Oct 20, 2009 | 10:42 PM
kolevski's Avatar
Ok guys back again,
Went to the exhaust shop and the guy is finding it hard to find CATS that fit where the primary cats are!
He put this question to me put straight pipes where the primary cats are and put the hi flows in place of the secondary easy to do...question is will the car run normally? I know it has a sensor just after the primary cat I have no idea what the car will do without a cat there! if anyone has an idea please chime in!
deerhunter
Jan 16, 2021 10:56 AM
Sep 28, 2015 07:40 PM
Idrenak
Sep 19, 2015 08:17 PM
Sep 13, 2015 02:12 AM
Jul 29, 2015 06:13 PM
