Pulley Issue?
Old Dec 5, 2009 | 04:06 PM
32krazy!'s Avatar
Default Re: Pulley Issue?
Originally Posted by MikeR
Hey, I dont have that one......does it fit the LET/ASP pulleys too? When I took mine off the only thing I checked was to make sure the holes lined up.
not sure mike. i think thats the tool they use but you should prolly ask jerry ar wayne to be sure.
Old Dec 5, 2009 | 04:22 PM
70GT6's Avatar
When they did mine they blocked the flywheel through the access panel.
Old Dec 6, 2009 | 10:49 PM
testknight's Avatar
I live in Greenfield, but work on the upper west side of Indy near the pyramids.
All.. for future tech reference the best way I found to get the pulley off:
1) Open the tranney access panel, its a plactic access panel that it vertical to grount facing front of car. Unplug any sensor or move all wiring out of way.
2.) under car, turn crank until you see a bolt head in flywheel area. Use a deep socket and socket wrench to take it off (I used a 1/2 cuz I couldn't find my 13mm deep)
4.) Take the bolt to your bolt box (if you've done enough car work, you have one of these... or go to HW store) to find an about 4 inch bolt with same size thread. My bolt box had a perfect bolt. screw bolt into flywheel hole about and inch
5.) I stayed under car and turned crank (using a breaker bar hanging down so I could reach it from there) until it hit side of acces panel opening (just to be sure nothing was in way and would get crushed.)
6.) using a breaker bar and a 4' heavy metal pipe (mine even has some concrete at the top of hadle for more weight..made just for job like this) crank on it until it comes free.
Need to pull my seal out next...was thinkg it would just come right out, not so. It was getting late, so I didn't mees with it much yet.
tom2112
Oct 26, 2015 08:18 PM
Wolf_7
Aug 26, 2015 06:37 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
Tp'sfury
Aug 13, 2015 08:20 PM
Jul 29, 2015 06:13 PM
