IC Pump
How do you know if the IC pump is working. I put a new one in and cant hear anything. Havent driven it yet. Its pouring outside. I satrt it up and let it get to running temp and hear nothing.. Wired the red to red and the blue to brown, is that correct?
If you look at the fac pump it is labeled at the plug for + & -. After installing mine I could not hear it run even after reving the motor to make sure it kicked on. The only 2 ways to know for sure are to drive it and see if the SC cuts in and out or to have some type of monitor like a dashdaq or program that will let you hook up a pc to your obd plug then you can check your Intake Air Temp. I knew mine was working thanks to my dashdaq and watching the IAT temp. Before putting the car back together I even tried touching the pump and could not feel it running.
start the car and rev the engine to 2000 rpm. this should start the pump. the pass side fenderwell has a door . open it and reach inside and feel the pump. if its running you will feel the vibration of the pump.
if you dont recheck the fuses and the wiring
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
