Rough Idle
Old Jan 24, 2010 | 05:34 PM
gxmeyer's Avatar
Default Rough Idle
Hi All,
I have had my Xfire SRT-6 for 3 months now and love it, last month I starting having an annoying idle issue. I started the car and it sounded like it was running on a few cylinders short and rocked from side to side. I turned off the car and started it again, all good.
Last week I came to a round about and the car just died, started it up and the same thing (WTF). I managed to drive/crawl down the road and parked.
I called the AA after the 5th attempt, hour later the AA arrived and the problem had gone. He checked for a error code but nothing. I called the Chrysler dealer and managed to get the car in that day.
They said that the couldnt find any issues but had replaced the plugs.
Last night the car did the same thing at a traffic light, this time put the car in Park and it was fine. This morning after driving 30 mins or so parked at the shops for 5 mins started the car and again very rough idle, misfiring and the rock. Had to start the car 3 times before it was OK.
I did think fuel the first time, but now dont think this is the case as it has happened at all fuel levels and I have filled 2 or 3 times.
ANY HELP PLEASE.
Thanks
Gareth
Old Jan 24, 2010 | 05:37 PM
Default Re: Rough Idle
crankshaft position sensor.....
Old Jan 24, 2010 | 05:44 PM
CRM could have a crack as well, search both from the "search feature"....or some of the others may post up as well....good luck
Old Jan 24, 2010 | 05:48 PM
gxmeyer's Avatar
Thanks, I will let you know once I have spoken with the dealer.
Old Jan 24, 2010 | 05:51 PM
bmorgan's Avatar
Could it be the IC pump?
Old Jan 24, 2010 | 05:54 PM
Xray's Avatar
Make sure that all of the plugs are seated nice and tight in your ecu. On 2 different occasions I have dropped cylinders and gotten a misfire code. Fixed both times after unplugging ecu and making sure to replugin nice and tight. Since your problem seems to correct itself this is probably not what is bothering your car but you never know.
Old Jan 24, 2010 | 06:14 PM
MikeR's Avatar
It sounds like the crank shaft position sensor to me also....... pretty easy fix...about $80 and 15 minutes....
did you get a CEL also?.. P0335?
Old Jan 24, 2010 | 06:33 PM
gxmeyer's Avatar
Hi Mike,
The car isnt showing any error code, which make me wonder if its not the ECU it's self.
Old Jan 24, 2010 | 11:36 PM
MikeR's Avatar
It might not throw a code... mine did, but others didn't... there are a couple of good threads here on the crank position sensor... just put that in the search and you should get lots of info...
Old Jan 25, 2010 | 05:25 PM
gxmeyer's Avatar
Hi All,
Thanks for all the help, the vehicle has been booked in for a week with the dealers to do a full scan. I mentioned all your thoughts and they have said it doesnt sound like the crank sensor due to no issues restarting just very bad mis-fire with power loss. The car did it again today after trying to accelate from a light. Sort of died and then suddenly full power which makes me think fuel again.
Will see what they can find.
Thanks
Old Jan 25, 2010 | 05:46 PM
ZAHANMA's Avatar
For some reason my initial reaction was clogged/blocked fuel injector causing a cylinder to go lean...next was the aprk plugs not causing spark, you could identify this by checking your tail pipes for excessive black residue on the edge (not interor, that is painted black on the SRT). It does sound somewhat like CPS, but you are right that if you have had no restarting issues it is not likely the cause.
Old Feb 1, 2010 | 09:44 AM
gxmeyer's Avatar
Hi all,
Still haven't got the car back, they have checked the crank sensor, for fuel issues and plugs but can't find the fault. Any other ideas?
Thanks
Gareth
Old Feb 1, 2010 | 11:42 AM
MikeR's Avatar
I believe that the camshaft sensor will cause a similar issue.....
Old Feb 1, 2010 | 06:34 PM
Goldwing's Avatar
Under wide open throttle I blew the air intake temperature sensor loose. The car ran like $hit, would not idle, and threw a bunch of codes. Does not sound like your problem unless it is a slight leak. Anyway, have them check and make sure all the sensors in the intake path are tight.
Old Feb 2, 2010 | 07:59 AM
Coyote's Avatar
Don't forget to have them check your rmotor mounts and make sure they
are secure. With all that rocking you described, this might not be a bad
idea.
Coyote
Old Feb 2, 2010 | 08:08 AM
velociabstract's Avatar
The manifold bolts are loose! Mine have to be tightened all the time. Just a possibility.
Les
Old Feb 2, 2010 | 09:50 AM
PA/XFIRE's Avatar
HOW ABOUT CHECKING THE FUEL FILTER, WHEN YOU STOP AND THINK ABOUT IT OUR CARS ARE 2005-6, ALOT OF THEM SAT AROUND FOR TWO YEARS BEFORE THEY WERE SOLD.I ASSUME THE GAS LAYING IN THAT FILTER WOULD GUM UP. JUST MY 2 CENTS WORTH. ILLCYA
cdcrone123
15
Nov 10, 2022 10:47 AM
crossfireusa
Oct 28, 2015 12:03 AM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
SRTFAN
Aug 27, 2015 01:25 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
