Another TVT Monster!!!
Old Feb 5, 2010 | 08:07 PM
TVT_DESIGN
Guest
Posts: n/a
Default Another TVT Monster!!!
Here are the details:
  • 185mm Eurocharged Pulley
  • 70mm SC Pulley
  • SL55 Intake
  • TVT Aluminum Intake Tubes
  • Needswings Devil Horns (absolutely sick in person!)
  • KN Filters
  • Gasket matched plenums
  • Code3 Spacers
  • SL55 Fuel Pump
  • TVT 48 lbs/hr Injectors
  • Custom Dual Exhaust
  • E55 Heat Exchanger
  • Upgraded Coolant pump (Porsche...)
No numbers yet, literally just finished it. We are going to the Dyno on Tuesday. It's a Dynapack so we're looking at 360-370RWHP. Stock cars put 250-260 RWHP down on it.
Pics will come tomorrow, too tired now...
Old Feb 5, 2010 | 08:20 PM
JHM2K's Avatar
Default Re: Another TVT Monster!!!!
Is this the recipient of the SLK55 brakes?
PICTARS....
Old Feb 5, 2010 | 09:00 PM
maclovinX's Avatar
How do you feel about putting a spread sheet for the NA's?
Let's face it; we can't do what our SRT brothers can, so lay us out a list that offers the Bang for the Buck options.
We simply cannot aspire to the SRT level!
However, we still want to have a little more fun.
Please do not refer me to the posts! I think it's evedent by your post; this is a moving target!
Top Down as soon as I can melt this snow!
Old Feb 6, 2010 | 12:46 AM
downwardspiral's Avatar
What do you mean we can't do what they can? With a stock motor maybe, but there's no real limit to fast you can make a car go. How fast do you want to go, or better yet how much do you realistically want to spend?
Old Feb 6, 2010 | 03:56 AM
BrianBrave's Avatar
<--- Huge Horsepower
  • 185mm Eurocharged Pulley **
  • 70mm SC Pulley
  • SL55 Intake **
  • KN Filters **
  • Gasket matched plenums **
  • Code3 Spacers (LET Spacers)
  • SL55 Fuel Pump **
  • Custom Dual Exhaust (Resonator Delete)
  • E55 Heat Exchanger (LET Heat Exchager)
  • Upgraded Coolant pump (Porsche...) (Jognson CM39)
Made 362 rWHP With those mods.... And what a monster!!!
Old Feb 6, 2010 | 05:23 AM
Bazzer's Avatar
Sweet graphs. 4300rpm looks like a nice place to be.
Old Feb 6, 2010 | 12:00 PM
TVT_DESIGN
Guest
Posts: n/a
Photos posted under "Ron's Car" TVT Design, Crossfire Performance Parts - Customer's Cars
We have posted a list of mods on our "Free Stuff" section of our website for the NA.
This is not the car getting the SLK55 brakes.
The LET spacers are too thin to allow for the Injectors to fit.
This thing NEVER goes lean!
Old Feb 6, 2010 | 03:22 PM
240M3SRT's Avatar
What is max boost and have you datalogged AFR's on the street in sub 50 degree weather?
Old Feb 6, 2010 | 04:14 PM
TVT_DESIGN
Guest
Posts: n/a
We'll have all that on Tuesday with the dyno run. It's about 20 degrees here.
The other car we did with a similar set up held under 14.0 in 30-40 degree weather and with smaller injectors then this one.
Old Feb 6, 2010 | 09:14 PM
Squirrel Crusher's Avatar
Soooooo...Is this Porsche,Jognson CM39 pump the new way to go over the Johnson pump? Squirrel Crusher
Old Feb 6, 2010 | 09:29 PM
ZAHANMA's Avatar
You could just got with the CM90 instead of the CM30 though I believe the CM90 requires a good bit more modification to make work.
Old Feb 6, 2010 | 11:45 PM
TVT_DESIGN
Guest
Posts: n/a
The thing with the coolant system is you need to have a pump that works in conjunction with overall cooling surface area as well as overall coolant volume. Some may think a pump that flows 50+gph would be great, but in reality it will pass by a small system so quickly that very little heat will be dissipated.
This pump is ideal for the E55 HE upgrade and a small coolant reservoir (not installed). If we were to do something crazy like we're attempting on another SRT, then a bigger pump would be justified. We're squeezing a monstrous HE (customer's choice) and seperate coolant tank into the car and will most likely run a CM90.
The CM30 is more then adequate for 90% of applications.
Old Feb 8, 2010 | 12:03 PM
cross><hair's Avatar
Stacked (181 + sc) and it's not leaning?
Old Feb 8, 2010 | 04:10 PM
TVT_DESIGN
Guest
Posts: n/a
48 lbs/hr injectors and SL55 fuel pump. Nope. And it's 185mm.
Old Feb 8, 2010 | 04:17 PM
distantpulse's Avatar
That is crazy! Regarless of running lean or not, aren't you worried about over-reving the supercharger?? I can see running the 178 + C3, but a 185 + C3 would be harmful to the supercharger, wouldn't it? I suggest running meth through that thing so it doesn't melt!
Old Feb 8, 2010 | 06:04 PM
mrphotoman's Avatar
very nice numbers!
Old Feb 8, 2010 | 06:36 PM
TVT_DESIGN
Guest
Posts: n/a
We are running a 185mm and a custom ground Stock SC pulley. It is just under the limit.
Old Feb 8, 2010 | 06:42 PM
Coyote's Avatar
Just how much can these engines handle? With that level of boost and
the fuel to go with it, aren't you worried about popping a valve? Dude,
that setup is wicked! Can't wait to see your dyno numbers.
Coyote
Old Feb 8, 2010 | 06:44 PM
Ahhh, very cool! you gotta get him to the track when it gets nicer out!
Old Feb 8, 2010 | 10:25 PM
TVT_DESIGN
Guest
Posts: n/a
Coyote
This is the second one we've done. We are limited on being able to fit our injectors with the availability of C3 spacers. I would look into manufacturing them, but the R&D cost won't support the limited market. Eventhough this doable with the C32 guys as well (we did one of those).
