SRT6, Locked up but not blown up???
Old Mar 25, 2010 | 02:02 PM
ronaldjfletcher's Avatar
Default Re: SRT6, Locked up but not blown up???
Originally Posted by 240M3SRT
This is a great post. Thanks for the info.
Do you think that an aftermarket wideband sensor would have picked up on this and read rich, so the driver would know what was going on?
I did have a pillar O2 and it was running rich, got it tunned so that it wasn't so rich but I think that the real damage had already been done before hand because of the injectors that were dumping fuel instead of spraying fuel which still continued after the tune.
Old Mar 25, 2010 | 02:06 PM
Originally Posted by tighed1
Now yer scaring me! My roadster runs waaaay rich judging by the looks of the tail pipes. Actually get black deposits on the rear of the car from the exhaust.
Thanks goodness for the extended warranty!
My tips were black as well... but I am talking very black and very noticable too. With the bad injectors I could see fuel spraying out the back when I hit it hard. If only I knew then what I know now I may could have saved the engine.
Old Mar 26, 2010 | 01:10 AM
240M3SRT's Avatar
Well, thanks again for comming on here and being so open and honest with us about what happened to your engine.
So what is your plan of action. A quick fix of some sort(wondering if you could replace just that one cylinder with engine in the car)? Replace bottom end all together? Junk yard long block assembly.....?
Old Mar 26, 2010 | 08:03 AM
I am going to replace the engine with a used one (junk yard) for now to limp by for a few months or so. Then I would like to have the seized engine rebuilt with better "race performance parts" like rods, pistons, heads, bigger head studs, cams, bearings ect.... what ever is possible will be done, less the making of parts.
1 cylinder seized and the other well on it's way to being, because of the two faulty fuel injectors. I am having the injectors assessed now, to find out if two brand new injectors went bad or was I sold faulty used injectors as if they were new ones. I will know by end of next week on this and I shall report it to all who cares to know, no matter if the findings are good, bad or indifferent.
* In the future I will periodically check injectors, "especially after replacing them" and I don't care if they have been dipped in gold I still want to see that spray... It only takes 30 to 45 minutes to check them, to make sure that they are NOT dumping fuel.
The reason I am being open and honest (the only way I know how to be) is because I do not want to see anyone else go through this within the current offered service's and have the ability to notice faulty parts right away and hopefully before they can cause any substantial damages.
More than likely I could just throw in the used engine and walk away from it and still break even in cost but I am not going to do that.
I love these little cars, especially the SRT 6 and I will run it until the wheels fall off and I can't replace them.
Old Mar 26, 2010 | 08:56 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Good to see you on the forum Ron...not under this circumstance however. Have you had any talks with the gentleman that sold you those injectors and did the install? I am not going to name names either, but I am curious of his position in this.
Old Mar 26, 2010 | 09:06 AM
bmorgan's Avatar
Thanks for sharing the information with us, and I will be interested in the outcome of your checks on the injectors. It will be interesting to see what you do with the engine rebuild, and what kind of HP you can get out of it.
Old Mar 26, 2010 | 09:18 AM
No real talking as of yet, I am waiting on the results of the assessments first. However he is completely aware of two fuel injectors being bad and has sent the old stock ones back??? instead of replacing the the two bad injectors or the whole set for that matter (actions/behavior) and this is the only reason why I am having them assessed to find out if they were new injectors or old used injectors.
And many thanks for all the help while in Dallas from you and all the Dallas guys, a good group...!
Old Mar 26, 2010 | 10:02 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Glad I could help sir...I do not mind getting my hands dirty
Old Mar 26, 2010 | 10:49 AM
I don't mind either but I am still learning.
Old Mar 26, 2010 | 05:44 PM
32krazy!'s Avatar
a rebuilt engine with the s/c pushing twin turbos!!!!!!!!!
Old Mar 26, 2010 | 06:54 PM
240M3SRT's Avatar
....and thats why we call him 32crazy, lol.
Old Mar 26, 2010 | 07:17 PM
I will certainly post all "documented" information from the injector assessments, no matter if good, bad or indifferent.
Old Apr 28, 2010 | 03:07 PM
Ok, it has been a long time, here are some pic's and I am waiting on one more GREAT part to arrive.
Left to right; 1) old engine 2) super-charger 3) semi-new engine 12K miles 4) empty-bellied engine bay.
File Type: jpeg
File Type: jpeg
File Type: jpeg
File Type: jpeg
Old Apr 28, 2010 | 05:05 PM
bmorgan's Avatar
Did you ever get a result from the injector assessment?
Old Apr 28, 2010 | 05:21 PM
No not yet, I am waiting until the engines are swapped out.
The assessment is in two parts, the age of, if possible and which ones were dumping fuel and why.
So once I get my hands on the old engine, where it is going to be rebuilt, I can mark the injectors by way of their cylinder locations as they are pulled out and recorded on Video. I have to know in my own mind that they are marked correctly as I may need the information at a later date.
Old May 3, 2010 | 09:15 PM
Got word today the one GREAT part that I have been waiting on will soon be on it's way, it's where the rubber meets the road, the EUROCHARGED "High Throw" Torque Converter...! The low-end and mid-range power to the ground will no longer be slipping away from me.
Old May 3, 2010 | 09:27 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Anyone else already running this TC in their SRT6's?
Old May 25, 2010 | 03:57 PM
  #38 (permalink)
The local dealer has gotten the wrong engine twice, non super-charged. I have given them my solid leads so they can get the right engine and no mark up on the engine I FOUND...!
Old Jun 10, 2010 | 03:29 PM
  #39 (permalink)
OK, I got my SRT6 back on the road today and the belt is being eaten up and soon to fail, I will have my mechanic line it all back up again this weekend.
Now phase ll start's, fuel injector assessments (everyone knows why) and then on to building a proper race engine...!
*Note: The EUROCHARGED "High Throw" Torque Converter, it does work...!!!
Old Jun 11, 2010 | 04:01 AM
  #40 (permalink)
cruzinquick's Avatar
Pic attached....OUCH At least your back on the road.
