Valentine 1 Direct-Wired
Old May 23, 2010 | 07:37 AM
Kenek's Avatar
Default Valentine 1 Direct-Wired
Has anyone powered their V1 via hard wiring (i.e. using a switched power source from the cabin and not using the cig lighter)? And if so, any recommendations?
Old May 23, 2010 | 07:43 AM
32krazy!'s Avatar
Default Re: Valentine 1 Direct-Wired
been done a # of times on mbworld with pics and such
Old May 23, 2010 | 11:45 AM
Kenek's Avatar
I checked out MBWorld and all of the direct-wired DIY projects involved dismantling half the dash to access a switched power source for the cig lighter. I'm not really wanting to remove all those dash panels.
I dropped the overhead lights and there are a number of wires for the lights and a small wire loom with six or so wires for the garage door buttons. Anyone know if any of those wires are switched (on/off with ignition)? And if so, which one?
Old May 23, 2010 | 12:13 PM
mrphotoman's Avatar
you can buy one of these at any parts store and have access to switched power with no cutting or tearing up your dash.
Amazon.com: Bussmann BP/HHH ATM Add-A-Fuse: Automotive
Old May 23, 2010 | 09:17 PM
surely you have a test light if you are doing the wiring...just use it to find a circuit powered by the ignition, that will handle the voltage...start at your fuse box....good luck
Old May 23, 2010 | 09:36 PM
robby363's Avatar
This might be some help. Crossfire - Valentine 1 Install FAQ
Old May 23, 2010 | 09:58 PM
ask and you shall recieve...lol...
Dec 11, 2015 09:41 AM
Franc Rauscher
Feb 14, 2014 01:48 PM
Bazzer
Dec 30, 2009 01:24 PM
sonoronos
Oct 2, 2008 11:42 AM
liketheride
Oct 14, 2005 06:10 AM
