A.C. Blowing Warm Air.
Old May 24, 2010 | 09:19 AM
PA/XFIRE's Avatar
Default A.C. Blowing Warm Air.
1st time i used A.C. since i installed nw duel intake w/kn extreme filters.
Anybody that installed duel intakes having the same problem ? I can't believe i'm blocking that much air flow to the A.C. radiator,you think ? I'm running a let he so the only thing in front of the A.C. rad. is the extreme filters. Thanks for all your comments and thoughts. ILLCYA
Old May 24, 2010 | 10:36 AM
adriancin05's Avatar
Default Re: A.c. Blowing Warm Air.
Actually i am having the same problem. i have the dual Cai Needswings intake, all of a sudden it blows out hot air and i move the switch and await a few minutes and it goes back to normal. I don't know whats happening so if somebody has a idea pls share your opinion...
Old May 24, 2010 | 10:55 AM
JimmyJames's Avatar
I can not believe the air flow is the problem either---too many have this intake now. Check fan operation and freon levels and pressures.
Old May 24, 2010 | 01:48 PM
kingkub57's Avatar
Check and make sure you did not knock any connectors loose or off on the a/c system, just used my a/c today and its working fine also just installed the NW cai set up in a few months back, so far no problems
Old May 24, 2010 | 01:58 PM
PA/XFIRE's Avatar
I'm not having any hi temp problem with reg radiator coolant so i have to assume its not the fan.Guess i'll have to have freon and pressure checked.I thought maybe the extreme filters i used in inlieu of the reg filters might be the problem due to there size covering more of the A.C. rad .If there's anybody else out there that used extreme filters with the dual intake system what say you ?
Old May 24, 2010 | 02:21 PM
JimmyJames's Avatar
1) The fan has two speeds---make sure that the fan will go on high. The relay tells the fan by the ECU to go to high when you turn the A/C on. 2) See if the A/C clutch is engaging. The post above could be correct. During install something could have been disconnected or broken. If the A/C clutch engages and STAYS that way, then you have freon in the system, or the low pressure switch would disengage the clutch. That will tell you that you have freon in the system or not. 3) If you have high fan and freon with a engaged clutch then the system could be blocked at the expansion valve at the bottom of the evaporator---smallest point. Only way to tell this is with gauges to measure the pressures. If the high side is above 250 or so and the low side is below 30-35, then something is blocking the system from flowing. Stop the A/C or you will do damage to the compressor, as well as, other seals, etc. Good luck---Jimmy
Old May 24, 2010 | 04:50 PM
Infinite's Avatar
My car blows hot air for the first few minutes the a/c is on and its stock intake wise... These cars have high underhood temps, so the condenser has to cool all of the hot freon in the system before it gets cold, and theres a fair length of a/c plumbing under hood.
That being said, if it only does it when the car isnt moving it sounds like a fan problem. If it does it all the time you could have a freon problem (low pressure, leak, or something) or the a/c compressor is on its way out. If you have low freon levels and pressures and are still running the a/c the compressor wont be properly lubricated and will prematurely fail
Old May 24, 2010 | 05:26 PM
FireAnt's Avatar
Default Re: A.C. Blowing Warm Air.
Sounds like a seal blew...Check the compressor...If the electrical connection is good but it isn't spinning then the signs all point to lack of freon.-Rusty
Old May 24, 2010 | 10:04 PM
Arizona John's Avatar
I installed the Needswing dual CAI in January, and everything works just fine. It is already quite warm here in Phoenix, so if the CAI or filters had any influence on the AC that would have showed itself immediately. Sorry,
but it must be something else.
John
Old May 24, 2010 | 11:53 PM
The air blows through the evaporator and then the heater core. Any residual heat in the heater core and plenums etc will have to be removed for full cooling, it does not blow cold until it all cooled down or the mix is reached.
Old May 25, 2010 | 09:43 AM
PA/XFIRE's Avatar
Reading the e-service manual on a.c. system operation, i can see without all the special gauges and tools this is a job for the pro's.A good test for using my extended warrantee at the dealer
i purchased it and my car. I'll get back with the cause and the solution,mean while i might as well roll down the windows enjoy the sound of the engine and the wind blowing thru my scalp (thin hair). ILLCYA P.S. Appointment made at dealer friday 28th 8:00am.
Old May 27, 2010 | 03:25 AM
cruzinquick's Avatar
John
I'm in Az with duals and no probs. Here is AZ the A/C takes a minute to cool down because it's so hot in July but cools down real quickly after that. I know it's obvious but is the red light lit up on the A/C button? Or can you see/hear your compressor come on and off?
Old May 27, 2010 | 03:46 PM
PA/XFIRE's Avatar
AC button light is lit,i think i hear the compressor going on and off.I'll have the dealer take care of it under the max care extended warranty.tune in tomorrow
for the rest of the story.ILLCYA
Old May 28, 2010 | 01:29 PM
PA/XFIRE's Avatar
Ok, now after the dealer recharged the system w/r-134 its working fine. My max care warrantee took care of the complete bill.(invoice marked warrantee #xxxxxxx/ no charge). Thanks guys, ILLCYA PS-Looked at a 2007 grand charokee srt-8 (black) while i was there, ($31000) one of the mechanics bought it after i looked at it.
Old May 28, 2010 | 03:54 PM
JimmyJames's Avatar
Did they replace any o-rings or hoses, etc? Freon does not just come out or get used up. I am glad that it's working!!!!
Old May 28, 2010 | 06:16 PM
BrianBrave's Avatar
<--- Huge Horsepower
Did they say anything about your mods?...
Old May 29, 2010 | 08:04 AM
PA/XFIRE's Avatar
O-RINGS, THEY SAID TO COME BACK IN TWO WEEKS FOR A FOLLOW UP
CHECK. (PROBABLY TO DRAIN MORE OUT THE CHRYSLER ON THE WARRANTY)
ILLCYA
Old May 29, 2010 | 08:07 AM
PA/XFIRE's Avatar
NEVER SAID A WORD BRIAN.
rperry52@live.com
Feb 14, 2019 12:18 PM
minimayhem
16
Aug 23, 2016 07:47 AM
Ed Mahoney
Sep 20, 2015 10:35 PM
caseydeankopp
Sep 13, 2015 07:25 PM
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
