Shifty shifting.
Old May 25, 2010 | 10:13 AM
tunaglove's Avatar
Default Shifty shifting.
When I make a pass and really give'r on the highway the car downshifts nice and pulls very well. Then when I quickly let off the gas to avoid overtaking lesser vehicles the car stays in the lower gear keeping the RPMs very high (5000+). I usually bump the autostick to + once or twice if it went to 3rd to resume cruising at normal RPMs. Is this normal?
Old May 25, 2010 | 12:27 PM
Headlock's Avatar
Default Re: Shifty shifting.
Yes, it is an auto stick so once you shift it yourself it does what you tell it to do. But once you hit it to the right until "D" then it will be back into automatic.
Old May 25, 2010 | 12:32 PM
tunaglove's Avatar
Yes, but I'm leaving it in Drive the whole time.
Old May 25, 2010 | 12:42 PM
Thumper SRT6's Avatar
This is normal. The car keeps you in the power band so you can "get on it" again. This feature threw me off the first time it happened to me, too. The transmission will shift on it's own eventually, if you don't do it yourself.
Old May 25, 2010 | 12:46 PM
Thirteendog's Avatar
It say's 3 on your dash, but you didn't manually downshift it?
Old May 25, 2010 | 02:59 PM
tunaglove's Avatar
Ok cool thanks Thumper, and no the display stays "D". I'm letting it kick down on it's own .
Old May 25, 2010 | 08:19 PM
70GT6's Avatar
You should try a SRT8. Those have an aggressive tranny module. They do the same as listed above plus the harder you brake the more the tranny downshifts. Great from braking in to a curve and stays in a low gear for exiting the curve. Lots of fun for a bigger car.
KrzyFast
Apr 14, 2017 02:16 PM
klamathpro
Other Cars Etc
May 19, 2014 12:37 AM
bby412
Apr 26, 2014 06:52 PM
Scott_lmtd
Jan 14, 2013 11:03 AM
Coyote
Dec 10, 2008 10:35 AM
