Aero pics with Eibachs & adjustable camber arms...
Old Jul 4, 2010 | 08:21 PM
MikeR's Avatar
Default Aero pics with Eibachs & adjustable camber arms...
Here are some decent pics I took a little bit ago at one of the (many) micro-brewery's here...... I just install the TVT adjustable camber arms today and set them so I have about 10mm-11mm of negative tilt from the bottom of the rim to the top edge... this looks to be close to factory or a little less...... this also has the 10mm spacers in front and 12mm in back........ (a few more in my gallery)..
Old Jul 4, 2010 | 09:51 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Aero pics with Eibachs & adjustable camber arms...
~ perfection...
Old Jul 4, 2010 | 11:34 PM
A+ very nice
Old Jul 5, 2010 | 07:06 AM
kolevski's Avatar
Hey Mike looks great!
How do you find the ride? I know a few members like the stock SRT springs better! what are your thoughts?
Old Jul 5, 2010 | 07:53 AM
velociabstract's Avatar
Car looks stunning as always. Hit some big potholes if you can, I'm curious about the 12 mm in the rear. (I have 10mm on the front too) I believe the suspension adds positive camber when the lower control arm passes horizontal, but I'm not 100% positive. Either way, stunning, stunning.
Les
Old Jul 5, 2010 | 10:46 AM
MikeR's Avatar
Kolevski, So far the ride is fine... I have had the springs in for about 4 weeks... I may take it for a drive to the coast today and see how it handles going through the mountains.....
Les, I intentionally try NOT to hit pot holes...the road to the coast has some areas that are a little rough and some sunken grade areas that drop or rise from repairs....
I forgot to mention that I finally FIXED my rattle in the back... I have been living with it as all the usual fixes... havent .....
I had read on here that someone mentioned the wing being loose might be one cause and since I had my wing and base off Saturday to re-seal I was hoping that might be part of it..... not!
Then while I was installing the adjustable camber arms I needed to take the rotors and calipers off..... what's this.... left rear caliper top bolt is very loose..bottom is seated but not tight.....right side was fine. I didnt use any blue loctite on the bolts when I installed the new rotors and Goodridge lines. needless to say I did use loctite this time and tightened them.... the normally rattling ride from my house to the freeway is now nice and quiet......
Old Jul 5, 2010 | 10:54 AM
I try to miss them too but I manage to fail from time to time. I couldn't take the risk of contact at the track so I tried to make my tires rub. I guess a better way would be to lift the suspension on one side with a jack. I think I'll do just that to find out how much wider I can go, if at all. I'm glad you got the rattle fixed before it got worse.
Les
Old Jul 5, 2010 | 11:10 AM
MikeR's Avatar
Les.... jacking the wheel up would be a good way to check clearance under compression...the rattle was just annoying...as long as the bolts didnt fall out, it was just a floating caliper. Glad that I caught it and fixed it though.... caliper falling off would not be a good thing.. I had checked everything else on the rear suspension thinking it was coming from there... guess I should remember to check the basics first..
Old Jul 5, 2010 | 11:16 AM
I could have used that set up at CAA Mikey...lol....nice look....might have to look at that mod if I keep getting my butt spanked in the curves...then again, that's not the curves I enjoy looking at...nice look though, good work as usual. Coupe is on the road, so far so good...need a tune though, shifts way too soon...
Old Jul 5, 2010 | 11:52 AM
MikeR's Avatar
Yeah... I had the adjustable arms for some time now but didnt install until I saw that I had an inch or more of negative camber when the new springs had settled...
One of these days I will wear out the 255 Kumho's and get some 275 or 285's and will have to see if the rear spacers are too much...
steps
Apr 26, 2016 06:21 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
atdavis2
Sep 21, 2015 01:25 PM
ayebb
Sep 18, 2015 03:35 PM
