asp pulley
Old Jul 18, 2010 | 03:07 PM
lannyx's Avatar
Default asp pulley
hello to all,after cai i buyed an asp 178 pulley kit from rob,and i want to know if i can go lean with this setup or the factory ecu can support this mods in safe
tank s in advice
Old Jul 18, 2010 | 03:21 PM
KrzyFast's Avatar
Default Re: asp pulley
No, you are fine running a CAI and a 178mm pulley without a tune.
You will need a tune to maximize the benefits of the combo however.
If you run a 181mm pulley, 185mm pulley or run a "stacked combo" 178mm pulley + a smaller supercharger pulley you HAVE to have a tune.
Install your 178mm pulley, with a new crank bolt and enjoy it!
Cheers,
KrzyFast
Old Jul 18, 2010 | 03:30 PM
lannyx's Avatar
tank s for the fast answer,another thing:i lieave in italy iand i can t ship the ecu,for this i want to know if the flash procedure can be done by obd port,i can pay someone to flasht it in remote (like teamviewer)
Old Jul 19, 2010 | 02:36 PM
ProjectMayhem's Avatar
I think Inmotion has an option to mail you the flash tool but you have have to put down a deposit just because the tool is exspensive.
Old Jul 19, 2010 | 02:41 PM
brian_omeara07's Avatar
Cheers,
KrzyFast
I asked Rob about the whole new bolt thing, and apparently the stock bolt doesn't achieve full stretch anyways, so there's really no NEED for a new bolt on it.
Old Jul 19, 2010 | 09:35 PM
KrzyFast's Avatar
Good to know. I was always told by other members that it was torque to yield and that I would suffer the consequences for reusing the bolt. I elected to use a new bolt....$10 dollars from the local dealership seemed like cheap insurance to me.
I do agree, given the size of the bolt how it would be a one time use, but was too afraid to chance it.
Thanks again for the advice!!
Cheers,
KrzyFast
Old Jul 29, 2010 | 04:27 AM
Cheers,
KrzyFast
No problem, I do agree with you, for 10 dollars you might as well get a new one. But I wanted to get my 178 on ASAP. Next time I have the front end off (hopefully going to be doing something crazy here soon) I'll be putting in a new crank bolt.
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
