WTB Concentric Spacers w/matching Bolts
Old Aug 15, 2010 | 07:12 PM
PA/XFIRE's Avatar
Default WTB HUBCENTRIC SPACERS w/matching Bolts
PM PRICE,MM,AND CONFIRM MATCHING BOLTS THANKS
Old Aug 16, 2010 | 05:28 PM
cruzinquick's Avatar
Default Re: WTB Concentric Spacers w/matching Bolts
What are you trying to accomplish? I've used these before, but was to change the bolt pattern altogether.
Old Aug 17, 2010 | 06:05 PM
PA/XFIRE's Avatar
I SHOULD HAVE SAID HUBCENTRIC, OLD AGE IS KICKING IN.JUST WANT A WIDER WHEEL BASE.
Old Aug 18, 2010 | 11:51 AM
I have a set of 15mm and 20mm. I have both for my drag radial sets. The sets didn't need them to fit under the car, but the wheel I used was thinner than the stock wheels where the bolts went in. So best case is to take the wheel your trying to put on and see how many threads are left. Rob had told me that 7-8 were about what was factory. If you have more count how many more and measure that in mm to determine your spacer. If you have less than you need a longer bolt. I bought a set of ebay and cut them to stock length to have an extra set. The 20mm required I cut them a tad longer. Hope this helps.
Old Aug 18, 2010 | 01:59 PM
PA/XFIRE's Avatar
Hey cruzin thanks for the info,that gives me a good idea of what i need to do to find the right length bolts. ILLCYA,
LARRY
Old Aug 20, 2010 | 01:26 AM
No prob I had bought mine on ebay around 70 bucks for a pair. Have seen cheaper but was in a rush.
Old Aug 20, 2010 | 12:42 PM
MikeR's Avatar
Here is a good site for getting any bolt length you need and spacers.....
http://www.radusadirect.com/
Old Aug 20, 2010 | 12:58 PM
PA/XFIRE's Avatar
THANKS FOR THE INFO MIKE,I'LL GIVE THEM A CALL AS SOON AS I TAKE CARE OF THE CAMBER ADJUSTMENTS AND SEE WHAT MM SPACER I WANT TO USE. ILLCYA LARRY
syfi
Mar 28, 2026 04:14 PM
55chevy
Jul 22, 2024 02:31 PM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
04Fire
Sep 15, 2015 07:40 PM
