First time out racing the SRT-6
Old Sep 6, 2010 | 01:19 PM
srtswizz's Avatar
Default First time out racing the SRT-6
I went to GLD 9/5 for some open racing with my friend with his 02 Mustang GT with a kenne bell on it.
It was a event weekend there and me and my friend were basically the only street cars there haha. I had a lot of people approach me and check out the SRT and ask questions about it. Most were shocked to see the times it was running. I got 4 runs in a few hrs and here they are-
Run 1-
60' 1.954
330 5.493
1/8 8.380
MPH 85.51
1000 10.866
1/4 12.935
MPH 109.55
Run 2-
60' 1.957
330 5.526
1/8 8.435
MPH 84.95
1000 10.939
1/4 13.020
MPH 108.80
Run 3-
60' 1.995
330 5.517
1/8 8.388
MPH 86.04
1000 10.861
1/4 12.92
MPH 109.66
Run 4-
60' 2.021
330 5.519
1/8 8.390
MPH 85.91
1000 10.869
1/4 12.934
MPH 109.67
This is my first time out with this car and its only modification currently is an intake. I got my best 60' without any brake torquing and whenever I torqued it, TC would kick in a bit even when it was disabled. Do you pull the fuses when you race or just disable it in the cabin as I did? Tires are just Kumho ecstas stock size nothing special. Also have a code 3 waiting to be installed still.
My friends best run was
Run 1-
60' 1.909
330 5.394
1/8 8.187
MPH 88.46
1000 10.583
1/4 12.575
MPH 113.75
On nitto drags
Old Sep 6, 2010 | 01:30 PM
32krazy!'s Avatar
Default Re: First time out racing the SRT-6
did you have the esp engaged? your 60 ft times will drop to 1.7 or so with dr's you can also launch higher rpm with them. your times arent bad for stock and with a pulley and tune some dr's and practice you can smoke that stang!!
Old Sep 6, 2010 | 01:47 PM
srtswizz's Avatar
no I disabled esp for all the runs, it still flashes on the harder launches I tried
Old Sep 6, 2010 | 02:20 PM
32krazy!'s Avatar
the flashes indicate wheel spin thus the need for dr's. the lower tire pressures and sticky compounds of teh dr's allow me to launch at 1800 to 200 rpm without wheelspin.
also running clk rims drops a bunch of rotational weight. each wheel and tire combo is 38 lbs
Old Sep 6, 2010 | 03:48 PM
Holycrap's Avatar
Those are good times. I figured out that brake launching works on street tires a bit too late last time i went to the track. Did u have it on D or manual mode when shifting? Those 60' are just about right on street tires.
Old Sep 6, 2010 | 04:20 PM
srtswizz's Avatar
1st run was done in D and the rest done in manual mode auto shifting
Old Sep 6, 2010 | 08:31 PM
SRT6 Gang Member's Avatar
THREE 6S
Nice showing srtswizz!
I think your 60’ are off, they should be mid to low 1.8x and once you get more practice launching, you could pull a high 1.7x on street tires.
Old Sep 7, 2010 | 12:19 PM
goodgenes79's Avatar
60ft times are a science. It will depend on track prep, launch rpm and how well you can feather a throttle. These cars have a good amount of torque and are pretty light but 1.8's are fairly common on street tires. Great times for a stocker and keep it up.
Bifftws
Racing
Jul 28, 2015 05:31 PM
Romio
Jul 24, 2015 07:04 AM
UNDER PSI
Jul 18, 2015 02:12 PM
tom2112
Jul 12, 2015 04:41 PM
grip grip
Jul 4, 2015 12:36 AM
