overheating problem
Old Jan 9, 2011 | 10:53 PM
cubanbee's Avatar
Default overheating problem
I'm having overheating problems i loss power and the supercharger shuts down after it heats up. i'm idling fine at around 700 starting when it starts to over heat it's idling at about 650-600. I already changed the temp gauge sensor or what ever and im about to change the water pump. dose any body have any ideas of what it could be? thanks
Old Jan 9, 2011 | 10:57 PM
ini2's Avatar
Default Re: overheating problem
Try the super charger cooling pump, it tends to gunk up the veins of the pump and then no cooling takes place. temp will rise and super charger will not come online
Old Jan 9, 2011 | 11:03 PM
bmorgan's Avatar
It is you IC pump. Replace it with a Johnson pump, and life will be good. Instructions can be found here. https://www.crossfireforum.org/forum...nson-pump.html
Old Jan 10, 2011 | 11:49 AM
cubanbee's Avatar
Smile Re: overheating problem
Yea thanks for the input I already replace my i/c pump when I first bought the car a year ago but it could have gone bad again. I already ordered the water pump so I'm gonna try that first them I'll replace the I/c pump again thanks.
Old Jan 10, 2011 | 11:52 AM
cubanbee's Avatar
Yea the I/c pump? That's what I thought it might be but I already replaced it with a Johnson I/c pump a year ago could have gone bad I guess. Thanks for the input.
tcar32909
Aug 1, 2024 02:41 PM
eikon
Sep 9, 2019 10:16 PM
jimf
Oct 10, 2015 10:22 AM
Abaton6
Sep 24, 2015 10:14 PM
Den656
Sep 23, 2015 12:27 PM
