ecu expert
Old Jan 12, 2011 | 05:56 PM
lannyx's Avatar
Default ecu expert
hello to everybody i need an expert for risolve this issue
after jerry from eurocharged flash my ecu, the car have some problems with the new map,now we haved retry to reflash the ecu,but the ecu isn t recognized by the flas prog because now send a series of point instead the serial number data and we ha problem to reflash it
Old Jan 12, 2011 | 06:05 PM
Jason_HBC's Avatar
Default Re: ecu expert
Not to be a jerk, but if edit your post for clarity it may be easier to understand.
Old Jan 12, 2011 | 06:21 PM
Thirteendog's Avatar
Jerk ROFLMAO
Old Jan 12, 2011 | 06:49 PM
ImportLabSRT's Avatar
Jerk ROFLMAO
I agree, its hard to understand. From what I gather, you sent in an ECU to be flashed and when you went to install it in the car it does not work?
Old Jan 12, 2011 | 06:55 PM
Mr. Max's Avatar
I think I've got it. The flash didn't work but it altered the ECU enough to screw up the I.D. recognition.
Therefore, it's not re-doable with a new flash.
Old Jan 12, 2011 | 06:59 PM
lannyx's Avatar
yes exatly,any solution?
Old Jan 12, 2011 | 07:01 PM
someone needs to make it right....
Old Jan 12, 2011 | 07:24 PM
Did you send it back to Eurocharged? Did they say it couldnt be flashed back to stock? If so, thats messed up. Id be asking for a new ECU.
Old Jan 12, 2011 | 07:31 PM
Mr. Max's Avatar
Ditto************************
Old Jan 12, 2011 | 07:35 PM
JimmySkullz's Avatar
I only hear good things about "Jerry Tunes" I hope you get it worked out. But he should be able to program.
Old Jan 12, 2011 | 07:37 PM
lannyx's Avatar
i live in italy ,they have flashed in remote,i hope i don t need a new ecu.....
Old Jan 12, 2011 | 07:41 PM
Did you ever of have to remove your ecu? If so, make sure all the pins are lined up, I heard sometimes pins bend and can make thing go wacky
Old Jan 12, 2011 | 07:46 PM
lannyx's Avatar
no they have do by odb port
Old Jan 12, 2011 | 08:35 PM
ZAHANMA's Avatar
I hate to be Capitan obvious...but have you reached out to Jerry at Eurocharged? The Eurocharged guys do the right thing, always have.
Old Jan 13, 2011 | 10:58 AM
lannyx's Avatar
galletto is producted in italuy,they told me the version of the map is nt right for my sw version of the ecu,the only solution is to unlock it by kess system,so i have not the ecu backup map and i ll need to install a generic base map and tune with dyno and proper instruments
Old Jan 13, 2011 | 04:16 PM
Bladecutter's Avatar
Since your car is no longer driveable, you should just remove the ECU, and send it to Eurocharged, so that they can fix it properly.
You will be saving yourself any further issues.
Personally, I don't think their tune was the right choice for someone who lives in Italy, which most likely has different settings for a car that uses much different quality gasoline. That's probably what caused the software mess up.
They might have a way to fix it, though, and might have your original map saved.
BC.
Old Jan 13, 2011 | 04:50 PM
lannyx's Avatar
i live in italy i can t stay to much time witouth the car,i ll ask to jerry if have backuped the original map before flash
Old Jan 13, 2011 | 06:06 PM
EUROCHARGED's Avatar
The customer is in Italy. I flashed his car remotely with the same flash cable some of you have used.
The car started and drives, but I wanted to flash it again with the TRQ limiters removed.
Now, when I go to connect to the car, it doesnt display any vehicle information.
I suspect it is an issue with the PC. He will be trying a Windows XP box next.
Thanks everyone.
Old Jan 13, 2011 | 09:48 PM
32krazy!'s Avatar
jerry has over 600 tunes for the 3.2 engine alone. he tunes cars from all over the world. he may be experiencing the same problems i had when jerry tuned my 32. great tuner, fantastic tune, awesome cable , and unfortunatly a computer illiterate with a POS laptop!!!! took 2 days for the computer to stay online long enough to download the files. no fault of e/c at all but jerry never gave up. 10:00 pm he was on the fone working with me
Old Jan 13, 2011 | 09:59 PM
loungn14's Avatar
We actually do a serious amount of business in the middle east and dubai on a weekly basis.
99.9% sure its a cpu problem. If it was an ecu problem car would be a paperweight...
Funny thing about ms windows and drivers, sometimes they don't play well.
