My srt6 still overheating!!!
Old Jan 25, 2011 | 05:30 PM
cubanbee's Avatar
Unhappy My srt6 still overheating!!!
hey everybody im still havingn overheating problems and of course loss of power. I have alreay changed the thermostat, checked the water pump, and changed the i/c pump still having the same problem. the fan is working any body got any ideas?
thanks for the input.
Old Jan 25, 2011 | 06:13 PM
SRT6 Gang Member's Avatar
THREE 6S
Default Re: My srt6 still overheating!!!
Questions that came to mind.
1.How high is your engine temperature needle going?
2.Do you have a way of monitoring your IAT? (data logger/ gauge)
3.Have you flushed your coolant system?
4.Is your coolant tank full?
Old Jan 25, 2011 | 06:22 PM
32krazy!'s Avatar
have you checked or replaced the upper and lower hoses? they may be collapsing inder pressure and blocking the system. many hoses look fine but are to soft with age
Old Jan 25, 2011 | 06:40 PM
bmorgan's Avatar
Have you burped the system? A trapped air bubble can cause over heating.
Old Jan 25, 2011 | 07:11 PM
waldig's Avatar
Talking Re: My srt6 still overheating!!!
If your really overheating and done the work listed, Id say the hoses are not flowing water. Put a hose in the overflow tank on slow and take off the top hose and see that it flows out from the block after the engine is IDLEing and warmed up. I think you have air problems even still. Woody
Old Jan 25, 2011 | 07:20 PM
32krazy!'s Avatar
are you sure woody? gonna fill the coolant passages and radiator with water filled with minerals. then you have to completely drain and start over. gotta be a better way
Old Jan 25, 2011 | 10:15 PM
cubanbee's Avatar
1.just ahair over the mid way point it better after i changed the i/c pump but still having the same problem
2.no
3.no
Old Jan 25, 2011 | 10:17 PM
cubanbee's Avatar
thanks woody i will try that first.
Old Jan 25, 2011 | 10:20 PM
cubanbee's Avatar
well then i guess i would have to flush it out after anyway but it's a good way to check thanks woody and thanks everybody for the quick replies. I should have a reply by friday im busy with some school work.
Old Jan 25, 2011 | 10:21 PM
KrzyFast's Avatar
Your radiator fan is not plugged up backwards is it?
Old Jan 25, 2011 | 10:22 PM
cubanbee's Avatar
lol no why dose someone always say that on these posts?
Old Jan 25, 2011 | 10:26 PM
If it is just above the halfway mark, you are not overheating.
You need to drive your car with a scanner/reader hooked up to see the actual temperature when you think it is overheating according to the gauge.
James
Old Jan 25, 2011 | 10:28 PM
cubanbee's Avatar
oh ok i didn't know that i thought it started overheating when it passes half way.
Old Jan 25, 2011 | 10:33 PM
Not even close! You are not the first one to think that. I recall over several times that drivers in the Dragon thought their cars were overheating because it would climb just above the halfway mark. My fan don't come on until a hair over the halfway mark. Once I get driving my car again when the weather gets better, I am going to get the gauge above the halfway mark and then get the actual temperature on my reader.
James
Old Jan 25, 2011 | 10:48 PM
cubanbee's Avatar
James
thanks for the info james
Old Jan 25, 2011 | 11:21 PM
FYI
Old Jan 27, 2011 | 09:23 PM
cubanbee's Avatar
What do you think about the NeedsWings Intercooler Fluid Isolation Kit and i was also thinking of getting one of you intercoolers from there. Do you think i should try to flush it out first then get the kit or might as well get the intercooler anyways?
Old Jan 28, 2011 | 04:01 PM
cubanbee's Avatar
**Update** just got the coolant flushed nothing that big of a deal just a little brown no pieces of metal or anything. after the flush the car was running good but still losing power once it looked like the temp gauge jumped just over halfway it is taking longer now for the supercharger to shut off and the loss of power then before also it dosent last as long now.
Old Jan 28, 2011 | 05:38 PM
SoftballJunnkie's Avatar
It's ur alternator. Just had this happen to me today Chrysler diagnosed it for me. I would check that.
Old Jan 28, 2011 | 06:49 PM
Are you sure the new IC pump is powering up and working?
