SRT-6 Wheel Rim Cleaning and Polishing Questions
Old Feb 14, 2011 | 12:44 AM
mach2plus's Avatar
Default SRT-6 Wheel Rim Cleaning and Polishing Questions
Greetings. Very sorry if this is a re-thread, but i'm almost cross eyed now after reading over 100 pages of forum material and have decided to throw in the towel.
my question is what SRT owners have found to be the best products for cleaning our unique tire rims, and then for polishing them?
in the past i have used products like semichrome to polish metal rims with excellent results, but thought it best to ask first to see what you with SRT expertise recommend.
thanks and best regards -- bob
Old Feb 14, 2011 | 05:04 AM
crossfirefun's Avatar
Default Re: SRT-6 Wheel Rim Cleaning and Polishing Questions
I haven't done anything to mine yet. I am pretty sure that you will have to strip off the clear coat if you plan on polishing the wheels. I will let smarter people chime in though.
Old Feb 14, 2011 | 06:57 PM
bmorgan's Avatar
That was my immediate thought...... The SRT wheels have a clear coat, so no need to use any type of metal polish. I took mine off and gave them a good cleaning and then applied a coat of wax to the front and back.
Old Feb 14, 2011 | 08:04 PM
SRT SIX's Avatar
Agree with the others about the clear coat. There are some good wheel creams available.
Old Feb 14, 2011 | 08:39 PM
I use a brush very similar to this to clean my SRT-6 wheels. I start by spraying a mild wheel cleaner such as Turtle Wax F21 on the fronts wheels, brush them down and rinse. Then repeat for the rear wheels.
Amazon.com: Large Wire Wheel Spoke Brush
If the tires also need cleaning, I use Westley's Bleche-Wite concurrently with the wheel cleaner and scrub them down with a nylon bristle brush.
It takes me less than 10 minutes to clean all four wheels and tires.
Old Feb 14, 2011 | 10:28 PM
Goldwing's Avatar
There's nothing special about these rims. Pull the wheel and use one of the commercial wheel/rim cleaners, like the purple stuff. It usually takes some elbow grease and maybe a little light rubbing compound if the grease or brake dust is baked on. Then thoroughly wax it a couple times inside and out. Repeat annually at a minimum. Oh - also install a low dust brake pad.
Old Feb 14, 2011 | 10:55 PM
JHM2K's Avatar
Ultimate Test! SONAX Full Effect Wheel Cleaner - MBWorld.org Forums
Old Feb 15, 2011 | 12:03 AM
BrianBrave's Avatar
<--- Huge Horsepower
These are my favorites...
I might do something like this...
https://www.crossfireforum.org/forum...aero-blue.html
And I second these... (If you have the $$)
https://www.crossfireforum.org/forum...my-wheels.html
Old Feb 20, 2011 | 01:47 PM
mach2plus's Avatar
Greetings all.
Thanks for the info you provided. With it in hand I removed each of my rims this week and cleaned and polished them. My SRT has 16k miles and this was the very 1st time the wheels had been removed and cleaned, so they still had a lot of undercoating overspray on them. Much as noted in previous comments, the SRT6 rims are clear-coated, front and back, and whatever the clear-coat is, it's one pretty darn tough paint! I've always used Westley's Bleche-white in the past to clean tires and rims, but as the warning says, it is somewhat corrosive, so I've always tested it on everything that I use it on, just in case... So what i did here was isolate a 2 inch by 2 inch square area on the inside of the first rim with some painters blue tape, and i then put a good coat of Westley's on it for 1 minute to see what might happen... Well, I'm happy to say that absolutely nothing at all happened to the clearcoat, and that it didn't even soften. But what it did was leave the rim absolutely spotless! (see pictures) So here's my procedure:
1. put car in park and chock the 3 tires not being removed.
2. slightly loosen wheel lugs of the rim that you're gonna remove.
3. using car jack lift vehicle and remove tire/rim.
4. spray entire inside and outside of the tire and rim with westley's bleche-white.
5. let it stand for 30-40 seconds and then use a painters brush to mop all the bleche-white around and to help loosen up the grime.
6. spray the entire tire with a garden hose and then scrub the tire/rim with a soapy wash mitt to neutralize the bleche-white and clean the tire/rim. if you have a very stubborn area with undercoating on it, like i did, just spray it again with the westley's, let set, and then use a fingernail scrubber to remove it. then rinse and wash again, per above.
7. sun dry or towel dry and then apply your favorite wax. I used meguiars gold class on my rims and they turned out great.
Potential gotchas: when spraying the bleche-white or whatever product you use, be sure that your car, or anything else for that matter, isn't around or downwind of the spray, which is typically corrosive. have your garden hose at ready just in case.
thanks again for your help, and best regards to all -- Bob
Old Feb 20, 2011 | 01:57 PM
JHM2K's Avatar
Great job!
PimpDaddy
Sep 29, 2016 11:55 PM
tom2112
Dec 1, 2015 09:02 AM
Indelibility
Aug 27, 2015 10:21 PM
tom2112
Jul 28, 2015 08:12 AM
axnguyen
Jul 21, 2015 11:41 AM
