Hiccup at 80...
Old Mar 15, 2011 | 12:19 AM
racer inc's Avatar
Default Hiccup at 80...
I was running down the interstate at 80mph 1/2 way thru a 5 hr trip when I crossed a bridge seam that upset the car a little. That is when panic set in. Four dash lights came on (light out indicator / Antilock warning indicator/ Oil level ind. light + ESP indicator) and the car shut off when all the lights came on for about 2-3 seconds (RPM dropped from 3k to 2K). Then it all came back on and the lights went out . All exept the ESP flashed 3-4 x and then stayed on. I pressed the ESP button and then the ESP light went off. The car ran fine the next 2 hrs. Is there some thing i should look into or just let it go. I have had the car for 8 months with no issues. ( 2nd owner , 51k ,srt-6)
Old Mar 15, 2011 | 07:20 AM
wildernesspeet's Avatar
Default Re: Hickup at 80.......
If ever there was a place to find great people with helpful answers, this is that place. I'm sure you'll get many helpful responses, but this may or may not be one of them. This exact thing happened to me a few months prior to additional symptoms showing up. Eventually my car started showing all of the signs of the "RCM soldier problem." It would stall and I'd drift to the side of the road, only to wait a good time before it would turn over and restart. I did the "fix" described here on the forum and have not had any of the sympotoms for the past 3 thousand miles. Good luck.
Old Mar 15, 2011 | 08:17 AM
mdaniels4's Avatar
Default Re: Hiccup at 80...
yeah, could be that, but the bounce from the seam is the catalyst, so check your battery posts to make sure they're on tight. one could have momentarily lost contact.
Old Mar 15, 2011 | 10:17 PM
racer inc's Avatar
Thanks to all. I will search your thread. I got 20k + 2yrs left on the warranty, so I have some time if it turns into an issue. . I 'll watch out for other issues.
Old Mar 20, 2011 | 02:25 PM
racer inc's Avatar
Wow, When I opened the plastic case there was silver dust at the bottom under the spot u said to look for. by eye it does not look bad but under a magnifing glass u can see the post with the crack around it in the soder. Thanks
Old Mar 20, 2011 | 02:56 PM
Good call...would have been a good first look...definitely a power loss for a moment...
Old Mar 21, 2011 | 10:15 PM
Be careful soldering it. First try, I put too much solder on it and it flowed too far. Had to cut it out, clean it up and try again.
Glad we could help.
frogwash
Aug 14, 2015 03:44 PM
hecti
Apr 1, 2014 09:03 AM
captain_winkie
Dec 13, 2011 10:11 PM
BLKFIN
Feb 20, 2009 10:32 PM
ShawnQ
Oct 24, 2007 04:10 PM
