181mm Crank Pulley $115
Old Apr 1, 2011 | 03:01 PM
Montana Crossfire's Avatar
Default 181mm Crank Pulley $115
This is a pulley to put on YOUR HUB.
Pulley has only a couple miles on it.
If you have wondered if you would like to try a different size crank pulley on your modified SRT this is a great opportunity.
$115 includes dilivery.
First come first served...
If you want it, Good Luck,
Mike
Old Apr 1, 2011 | 06:37 PM
SRT6_Roadster's Avatar
Default Re: 181mm Crank Pulley $115
I will ask as I am sure others are wondering. Is this just the 181 or does it come with the other 2 pulleys? I am guessing just the 181mm given the price. Can you purchase the other pulleys from Eurocharged?
Old Apr 1, 2011 | 06:56 PM
Yes this is just the 181mm.
You need to already have a 178mm, 185mm or have a Hub.
Mike
Old Apr 2, 2011 | 01:35 AM
MikeR's Avatar
Just to clarify..... this is the outside 181mm aluminum pulley ONLY... without the center steel hub....Correct Mike??
Old Apr 2, 2011 | 10:32 AM
Yes, Mike,
I am surprised I was unable to find the words that make this clear but I have had about 9 P/Ms asking this same question.
If you have a 178mm or a 185mm it gives you the opportunity to try out this 181mm for a fraction of the cost than if you bought the whole set up.
Hope that helps,
Mike
Old Apr 2, 2011 | 11:11 AM
Originally Posted by Montana Crossfire
Yes, Mike,
Hope that helps,
Mike
The word that was missing was - aluminum.
Old Apr 2, 2011 | 01:20 PM
Ah, but those whom have not dug into there SRT's are very likely to be unaware of the material used on their stock Crank Pulley hub
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 02:16 AM
