Acurate & cost effective way to monitor IAT's?
Old May 10, 2011 | 06:15 PM
kolevski's Avatar
Default Acurate & cost effective way to monitor IAT's?
As some of you may know I recently got my car tuned by Eurocharged by Clint & Jerry unfourtunatly the car is running like a pig and even with all my mods I couldn't beat 12.6 @ 111mph on a nice cool night.
Jerry has asked me to get a reading of my IAT's for him to know what to adjust. What is the best and cheapest way to do this? and where to you guys generally put the sensor? I dont want to hack into my Needswings manifolds. They have the bung for a boost gauge but I dont know if the IAT sensor will fit there?
Thanks for any help in advance guys.
John.
P.S
excuse the spelling mistake in the title!
Old May 10, 2011 | 06:28 PM
kolevski's Avatar
Default Re: Acurate & cost effective way to monitor IAT's?
Maybe the scangauge II ? atleast I wouldnt have to drill any new holes.
Old May 10, 2011 | 06:34 PM
32krazy!'s Avatar
it can be read thru the obdII port. i use my dashdaq to read them. the y pipe is were the oem iat sensor is located. thats also were i tapped the boost sensor
Old May 10, 2011 | 07:23 PM
SRT6_Roadster's Avatar
Isn't the OBD2 reading a bit slow to get an accurate picture for tuning? Better than nothing but far from ideal.
Old May 11, 2011 | 06:30 AM
maxcichon's Avatar
UltraGauge Automotive Information Center and OBDII Scan Tool
Works like a charm! cheap and fast shipping.
Old May 11, 2011 | 07:30 AM
kolevski's Avatar
I was actually about to buy that one, the only thing is it doesn't datalogger
I want something cheap to use with my laptop.
There is 'Dyno Scan' but im not sure if it shows IATs
The other option I have is the PLX Kiwi Wifi and the REV iPhone app that allows datalogging and then the option to email the logs which is pretty cool.
Old May 11, 2011 | 08:29 AM
Sik Srt-6's Avatar
Either tonight or tomorow ill be pulling my y pipe to begin tapping for by boost bung and temp sensor, i have a plx setup. Ill see if i can measure the threads on the temp sensor and shoot you over some info. There could be a chance it will fit in the bung you have already
Old May 11, 2011 | 05:10 PM
kolevski's Avatar
Hey man that's for that which PLX unit do you have the kiwi wifi unit or something else?
I found out that cars factory IAT sensor is in the y pipe so probably no need to put in a another one, but the y pipe is a good place to tap for boost.
Old May 11, 2011 | 07:56 PM
32krazy!'s Avatar
its fairly fast if you don't have to many readings going at once. its fast enough for the ecu so i use it
Old May 11, 2011 | 08:25 PM
Sik Srt-6's Avatar
Today i actualy bit the bullet and begain installing my boost bung, and IAT sensor.
Btw on the plx system, the K-type thermocouple, the thread is a NPT 1/8-27, and the tap drill size is 11/32, you can go with a Q drill if you have the fancy drill set. Its a special tap, and i have no ideal why they say its 1/8 because its much larger then a standard 1/8 tap. Also the tap is tapered so you dont run the tap all the way through the hole. I took a bunch of pics, and ill create a small thread on tapping the y pipe.
Btw i have 3 DM-200, and a IAT sensor, Boost/vac and A/F sensor moduel. Ive read i can datalog off of it, but havent tried tinkering with it all that much. I can do bar graphs on the gauges though.
Old May 11, 2011 | 09:47 PM
BrianBrave's Avatar
<--- Huge Horsepower
Similar to what I did only I used a standard 1/4 NPT tap for the boost and a 1/4 tap for the IAT sensor. After a few years of monitoring, I decided to go "sleeper" and removed all my gauges...
Valk
Jul 12, 2021 09:49 PM
rampntlion
21
Feb 11, 2019 08:18 AM
Apr 28, 2016 02:04 AM
tritongreen
Sep 18, 2015 07:32 AM
waldig
Sep 17, 2015 10:35 AM
