Intercooler Pump Questions
Old Jul 11, 2011 | 09:47 AM
Shakey's Avatar
Default Intercooler Pump Questions
I bought a new to me SRT6 that is stock, and still running the stock intercooler pump at almost 40,000 miles.
I want to change the intercooler pump now instead of waiting for it to go out.
I've searched the forum for all the information on the pump, and it's obviously a really easy swap.
But is there a consensus on what pump to use?
Stock Bosch?
Johnson, but if so, which one (I found two)?
The Ford Lightning pump?
I'm inclined to go with the stock Bosch, only because I know it will work (and I don't even find the Johnson on the Needswings website). There is a lot of information out there on the other two options, but I couldn't find any solid answers or data on them.
If I missed something and this has been covered, I'd appreciate a link to the thread and I'll continue reading.
Old Jul 11, 2011 | 10:02 AM
Shakey's Avatar
Default Re: Intercooler Pump Questions
Like I said above, I'm inclined just to use a Bosch replacement.
However, looking at this: Bosch Intercooler Fluid Pump
it looks like it's not exactly plug and play by looking at the wiring harness. Will I need to splice wires? Not that that is a problem, but I'm surprised if that is the case.
Old Jul 11, 2011 | 10:22 AM
tighed1's Avatar
After seeing how the stock pump impeller cracked for no reason, for peace of mind I just went with the Johnson.
Old Jul 11, 2011 | 10:27 AM
robby363's Avatar
The pump from NEEDSWINGS is the same as the ford lightning pump. I have the same pump that NEEDSWINGS sells and haven't had any problems with it. I had the Johnson pump and had to replace it about a year later.
Old Jul 11, 2011 | 10:43 AM
MikeR's Avatar
I have been running the Johnson CM30 for over two years now.... my stock pump did not fail and is sitting in a box in the garage.....
Old Jul 11, 2011 | 11:04 AM
Shakey's Avatar
Thanks for the quick responses, which seem to confirm my search results that there really is no answer. Given they all seem to have similar fail rates, the logical choice seems to go with the cheapest solution in a Bosch replacement.
Is there a plug and play solution, or do they all require splicing the wiring harness? I'm just trying to put my parts list together.
Old Jul 18, 2011 | 11:25 AM
Shakey's Avatar
Well that was easy. The hardest part was finding the "hidden" nut on the splash guard.
My soldering skills are also non-existent but I think it will hold.
I am surprised that no one makes a truly bolt-on replacement connector, and that you are required to splice wires though. I'm also surprised that the new pump (which I think is the Ford Lightning pump) is all plastic, while the stock pump's rotating assembly was cast aluminum. Based on that, I suspect the replacement pump will not last as long as the stock pump. But, time will tell.
In any event, my old pump was obviously intermittent and going out, which I suspected. It's nice to have power every time I step on the pedal now.
Old Jul 18, 2011 | 11:33 AM
yes sir....pumps are a power grabber when they don't function. The roadster/coupe are both getting their new pumps very soon. Roadster a CM 30, and the coupe will get one from Rob, asa I order it. Got to get the rearend done first....lol...then back up front for some changes, then underneath, as it just never ends what you can do to these cars.
Old Jul 18, 2011 | 02:13 PM
dinasrt's Avatar
Originally Posted by oledoc2u
"The roadster/coupe are both getting their new pumps very soon. Roadster a CM 30, and the coupe will get one from Rob, asa I order it."
Doc, If I remember correctly, you had the Johnson on the shelf already. Just curious why you're getting the one from Rob for your coupe instead of another Johnson. I thought the Johnson flows a lot more and helped w/ heat dissipation? I'll be doing this swap soon enough. I'm thinking that if the Johnson was better, Rob would sell that one, yes? Bob
Old Jul 18, 2011 | 02:23 PM
robby363's Avatar
I've had both in my car and saw no difference in performance.
velociabstract's Avatar
If I'm not mistaken the new Bosch replacement pumps corrected the failures of the previous generation and are now durable and the flow is improved. This is what I've gathered from a Benz forum. I don't know this for a fact however. I'm personally debating between the Bosch pump and the Johnson. I don't know which is better for our application but in Rob we trust, right?
Les
Old Jul 18, 2011 | 03:06 PM
I will be talking to Rob soon with that very question. I bought the CM30 johnson when LET was still in business. I'm sure Eurocharged has them, but I have been dealing with Rob on most parts. I think they all will do the job.
Old Jul 18, 2011 | 08:34 PM
dinasrt's Avatar
Les
So if this is correct, and Rob is selling the newer version Bosch pump, then I'll definitely go w/ Needswings for $45. less. I guess I could simply e-mail Rob and ask him.
Old Jul 18, 2011 | 10:39 PM
yep....he wouldn't sell junk....besides....everyone should keep a spare around...mine has sat on the shelf long enough, and I will keep a spare...I'm hope to tear into the roadster yet this week...I'm having the bumper cover repainted...rock chips...I have roll bars to install on it as well....taking the old roll bars and putting them into the coupe. The coupe is getting a lot work done as well, but that will be at the shop where we will do the LSD install. Lots to do before Woodward and the Dragon...but again....I think any of the pumps will do a good job for you...now if you had a super cooler like DJ and some others, the johnson would be the preferred pump because of volume and flow...
Old Sep 11, 2011 | 12:32 PM
Catharsis's Avatar
I'm debating between replacing the pump myself or having the dealership do it. I hear it's an easy thing to do, but I'd feel a lot more confident if I knew ahead of time what would need to be done. I assume the pumps come with instructions, but is there anywhere I can find those instructions online so I can see what I'm getting into?
Old Sep 11, 2011 | 07:24 PM
SoftballJunnkie's Avatar
I have a bosh pump for sale if anyone is interested.
Old Sep 12, 2011 | 11:30 AM
tighed1's Avatar
DIY!
Checkout this link that has multiple links about this.
LINK
Old Sep 12, 2011 | 11:47 AM
jsaredwings's Avatar
trust me do it yourself, i am by no means a car guy and i was able to do this without any real trouble. i believe the dealship wanted about $700 when i asked for a quote when mine failed 2 weeks after the car was off warrantee. I went with the Johnson and found it online for 140 shipped.
Old Sep 12, 2011 | 03:08 PM
Catharsis's Avatar
Thanks guys, you're awesome!
Jonacross
20
Jul 17, 2017 11:19 PM
Mackel
Oct 16, 2015 09:03 AM
81's
Sep 13, 2015 04:34 PM
lazorouss
Sep 11, 2015 09:16 AM
crmnal
Sep 6, 2015 08:07 AM
