srt-6 dyno
Old Jul 20, 2011 | 12:52 AM
svtcobra's Avatar
Banned
Default srt-6 dyno
I would like to thank jerry and the eurocharged crew for an excellent dyno tune my srt6 made 350hp to the wheels with the 185 crank pulley NW single and 2nd rear cat delete .I will be posting a dyno graph soon. Next mods booster pump or bigger injectors
Old Jul 20, 2011 | 02:26 AM
Mimi05SRT6's Avatar
Default Re: srt-6 dyno
350 sounds low for a 185 pulley and tune. What type of dyno, Mustang?
Old Jul 20, 2011 | 04:29 AM
magredvet's Avatar
My coupe made only 315 at the wheels with the mods in my sig, Apparently Eurocharged's Dyno is reading low for some reason.
Old Jul 20, 2011 | 11:45 AM
Buggin's Avatar
Dyno number are just that, numbers. The are really only good if you use them to reference your own cars gains, when using the same dyno. You will find they can vary a LOT between diff ones: Mustang, Dynojet, Dyno Dynamics, etc... Some setups even have auto correction for weather (temp, humidity, etc). So comparing 2 cars dyno'd on 2 diff setups is apples to oranges.
FWIW, 350 to the wheels is a very good number.
Old Jul 20, 2011 | 12:06 PM
dtinker's Avatar
Jerry and Clint both think it is reading about 10% low. They had some work and new software put in and now it reads low, but it is very repeatable. My2006 LTD Roadster reads 199.6 RWHP. I think it is doing about 220RWHP. It was reading 195 RWHP and have done two mods since (K&Ns and 74mmTB) Thought I would get between 215-225 RWHP with those mods. Runs good. Will add 74mmMAF tube later, should see some increae there too.
Old Jul 20, 2011 | 07:32 PM
tnhatch03's Avatar
what was the tq?
anything over 300 is fast!
Old Jul 20, 2011 | 08:21 PM
dtinker's Avatar
TQ for an N/A 3.2 is low, the graph looks like 199 Ft.# at 199.6 RWHP. The HP ,I think is low, but not sure on TQ.
Old Jul 20, 2011 | 08:39 PM
tnhatch03's Avatar
Interesting!
I was not sure if the SRTs were fairly close in terms of HP/TQ numbers since it was S/C.
But I am in for graph!
Old Jul 20, 2011 | 08:45 PM
Buggin's Avatar
You can see my HP vs. TQ in my sig above. The TQ on the supercharged 3.2 is usually a little higher than the HP number. Not sure if you caught that dtinker was giving figures for a N/A 3.2
Old Jul 20, 2011 | 08:48 PM
tnhatch03's Avatar
Ah! I see now! Great numbers! This is my first S/C vehicle and I have ridden in a handful and always enjoyed not having boost lag. haha
When tinker was talking about the graph, that is where my confusion was coming in.
Old Jul 20, 2011 | 10:48 PM
svtcobra's Avatar
Banned
the torque was also 350 they where sayin that i was starting to run lean over 5k rpm or they could have gotten more out of it and also i was dealing with some heat soak issues. so definitely i will need either a booster pump or bigger injectors to take care of the lean conditions
Old Jul 20, 2011 | 10:51 PM
JHM2K's Avatar
So... add me to the confused list... do you have a red SRT, or do you need to change your avatar?
Old Jul 21, 2011 | 12:35 AM
Mimi05SRT6's Avatar
Makes sense now. With this extreme heat this summer, numbers will definitely be lower. I put down 357whp (uncorrected), 364 whp (corrected) with my code-3 pulley, but that was earlier in the year when the temps were much cooler. Heat soak is a real killer.
Old Jul 21, 2011 | 12:40 AM
svtcobra's Avatar
Banned
sorry for the confussion i need to change my avatar picture. what would i need to do to reach the 380hp range any advice and with 350hp with good street tires what would i run in the quarter
Old Jul 21, 2011 | 04:43 PM
32krazy!'s Avatar
dont anything with injectors yet. theres something in the works! as for 380 rwhp robs dual cai his manis and your 181 should get you very close. torque should be in the 380 to 400 range
as buggin said donr worry to much about dyno # look at the gains from the baseline and the afr's thru out the run.
i have 357 rwhp and 372 ft/lbs and my street tire run in the 1/4 was a 12.5 at 111 mph. spinning thru 2 gears doesnt help!! i wouldnt worry to much about 1/4 mile times in fl. in july. wait until november and you will be a full 1/2 second faster!
Old Jul 21, 2011 | 07:55 PM
70GS455's Avatar
Any idea what the fuel pressure was doing during this?
Apr 28, 2016 02:04 AM
johnnycross413
Mar 4, 2016 04:49 AM
miscetera
Oct 5, 2015 11:40 AM
Sep 28, 2015 07:40 PM
Billy22Bob
Sep 18, 2015 08:57 AM
