Intercooler Pump Replacement PICS
Old Jul 23, 2011 | 05:26 PM
AlbertFattal's Avatar
Default Intercooler Pump Replacement PICS
I am still in the process of replacing the pump with the Ford Lightning Pump (got it on ebay for $104 including shipping and pigtail electrical connector)... Also got some pics of the suspension to get ideas on how to cut the springs 1/2 coil in front and 3/4 in rear!
Enjoy!
Default Re: Intercooler Pump Replacement PICS
Some more pictures
Old Jul 23, 2011 | 05:27 PM
Some more:
Old Jul 23, 2011 | 07:30 PM
waldig's Avatar
Talking Re: Intercooler Pump Replacement PICS
I hae been tryingg to post photos and the process is intermittant at best and broken now. How did you get the photos ( more than 4 ) to load on your posting?????Thanks Woodu
Old Jul 23, 2011 | 07:40 PM
I have the SAME exact problem, When I upload multiple images, crossfireforum.org breaks and I lose all the data! It's terrible!
I am just hotlinking them from my facebook alum now,
ex:
[ img ] imageurl.com: The Best Search Links on the Net. jpg [ /img ]
without spaces
IMPORTANT QUESTION!!!!!!!!!!
I lost a little more then normal coolant amount as I did not clamp hose tightly, may I get the Walmart Prestone 50/50 coolant and use - Can I drive the car to my local walmart with its low coolant level? Walmart is 3 miles away
THANKS!
Old Jul 23, 2011 | 08:29 PM
waldig's Avatar
Look in the radiator, if you see it it is ok to go three miles.Woody Thanks
Old Jul 23, 2011 | 08:44 PM
Buggin's Avatar
THANKS!
DO NOT, I repeat DO NOT mix antifreezes. These cars have G-05 Hybrid Organic Acid Tech antifreeze:
Valvoline.com > Products > Zerex > Antifreeze Zerex > Zerex G-05® Antifreeze / Coolant
You can also add a little deminerized water to top it off.
Old Jul 23, 2011 | 08:48 PM
32krazy!'s Avatar
its ok to drive it but its not ok to use prestone 50/50! either m/b coolant mixed with distilled water or zerex g50 nothing else
Old Jul 23, 2011 | 10:20 PM
I get butterflies driving again! GOD this car is fast!
SCORE FOR ALL SRT DRIVERS!
Drove it hard and no leaks, lookin good =]
Couple questions:
When the intercooler pump is replaced, doesnt air get into the tubes between changing the pumps? Do I need to bleed this air? Or does it just "pop" out into the reservoir tank on its own?
When one refills the "Intercooler pump antifreez coolant fluid" - do they simply place it within the radiator coolant reservoir near the battery?
Does this supply both for radiator AND IC Pump?
It still looks fairly healthy full, and if it's low, my car would tell me on the dash board anyways right? It runs GREAT and the car isn't warning me of anything, I think I'm good?
Old Jul 24, 2011 | 08:23 PM
I forgot to post the finished photos:
Old Jul 26, 2011 | 08:56 PM
SRT6 Gang Member's Avatar
THREE 6S
AlbertFattal
Yes, air will enter the system. Start the car and remove the reservoir cap, watch for bubbles. If you don't see any then you are good, if you see bubbles just let the car run until they stop. To expedite the process drive it hard, watch your temps though.
The reservoir is located on the passanger side near the headlight.
Yes.
You got it and nicely done.
Old May 13, 2013 | 08:20 PM
Djo's Avatar
Djo
Getting my intercooler pump replaced Wednesday by an independent Mercedes mechanic. He's never worked on a crossfire SRT but has been Mercedes mechanic for 20 years. My first major repair I'm afraid this is going to turn into a nightmare. I live in Prince William County Virginia and you just can't find anyone out here that's even either seeing one or is ever worked on one. Is the crossfire engine that much different then the Mercedes stock engine?
Old May 15, 2013 | 02:24 PM
syfi's Avatar
This page should esplain it all...
Chrysler Crossfire and SRT-6 general information and car review
BrenLW
Aug 5, 2015 04:53 AM
Romio
Jul 24, 2015 07:03 AM
RED DOG
Jul 21, 2015 07:58 AM
Beeker
Jul 20, 2015 03:46 PM
