Running Like Crap
Old Jul 31, 2011 | 04:11 PM
BLACKSRT-6's Avatar
Default Running Like Crap
Raced my car at the 1/4 mile on Friday and Autocross on Saturday then drove 60 miles home with no issue. Went out to move the car today and it is running like crap and throwing cells. A quick look under the hood and I notice the Throttle Body Spacer Gasket is ripped about 50% of the way around. Its a pain in the but to remove due to the fuel rail, I will get a replacement from the dealership on Monday.
Has anyone else noted this issue and is there a upgraded replacement part available? Thanks
Old Jul 31, 2011 | 04:38 PM
32krazy!'s Avatar
Default Re: Running Like Crap
no upgraded gasket that i know of. t/b isnt that hard to remove once the y pipe is out of the way. fuel rail shouldnt be any issue
Old Jul 31, 2011 | 05:19 PM
MikeR's Avatar
I have replaced mine twice and haven't taken the fuel rail off..... I keep a spare gasket in the tool box...
They only cost about $8.00 at the Chrysler dealer....
Old Jul 31, 2011 | 05:45 PM
BLACKSRT-6's Avatar
The fuel rail on my car crosses right behind the lower drivers side T30 bolt of the spacer. No real issue, I got it off in a few minutes. Guess i'll get a spare when I get the replacement tomorrow. Thanks
Old Jul 31, 2011 | 08:06 PM
Squirrel Crusher's Avatar
I'll take a look at mine in the daylight. If you could post the part number,it would make me happy! Squirrel Crusher
Old Aug 1, 2011 | 06:27 AM
BLACKSRT-6's Avatar
Here are the numbers off the part, do we have a list of PN's somewhere in here? A112141 2480
Old Aug 1, 2011 | 11:29 AM
BLACKSRT-6's Avatar
Well it appears this part is hard to come by. My local Alabama dealership is getting one brought in, but it will take 5 days becuase it is coming from Milwauke. The Mercedes dealer stated 2 weeks from Germany. This is not the O-ring, but the mounting base for the throttle body that is screwed to the supercharger and the throttle body is then screwed to it.
Old Aug 1, 2011 | 11:55 AM
MikeR's Avatar
Yeah, the MB dealers don't seem to keep this one in stock....the back end of the Crossfire SC is different than the SLK32/C32....they dont use this gasket....
I wonder which other MB does use it....
Edit: here is the Chrysler PN off the spare I have... 05159305AA. The MB PN given above is correct, A112 141 24 80.
Old Aug 1, 2011 | 07:38 PM
32krazy!'s Avatar
were in al are you located? ill be in al tommorrow and i have a gasket from my slk32 if it will fit. ill be in northern al from decatur to gunterville and back to nashville if you want it
Old Aug 1, 2011 | 09:03 PM
BLACKSRT-6's Avatar
Appritiaite the offer. According to Mercedes, the spacer used on the SLK is different then the one on the Crossfire. In case you make down this way again, I am located in Prattville just north of Montgomery. Thank you,
Old Aug 1, 2011 | 11:05 PM
Thanks for the part numbers. I'll add this item to my parts stock pile. Squirrel Crusher
Old Aug 2, 2011 | 12:42 PM
MikeR's Avatar
Steve, the SLK gasket wont work on the Crossfire. We have a rotational offset on the back of the SC and the gasket mounts to that and then the TB side changes the mounting to be horizontal... the SLK mounting is horizontal to start with.... I have two SLK line pipes(SC back end) if anyone needs one..
Old Aug 2, 2011 | 06:56 PM
32krazy!'s Avatar
Originally Posted by MikeR
Steve, the SLK gasket wont work on the Crossfire. We have a rotational offset on the back of the SC and the gasket mounts to that and then the TB side changes the mounting to be horizontal... the SLK mounting is horizontal to start with.... I have two line pipes(SC back end) if anyone needs one..
must be an amg thing!
roar
Jun 15, 2022 11:46 AM
Nov 11, 2015 05:22 AM
livefreeordie
Sep 22, 2015 08:13 PM
tritongreen
Sep 18, 2015 07:32 AM
RiderJC
Sep 7, 2015 11:19 PM
