purchasing my srt6 yet another hiccup
Originally Posted by boocher13
So what they are saying is that the car did not come with a 7/70 but this part is considered part of the emissions system.I will get a 90 day 3000 mile warranty by law from the stealership I'm buying it from anyway.
ok something is not right.I just got off the phone with Chrysler customer service I gave them the Vin and they told me the car does not have 7/70 it only had 3/36.I have the original title in front of me the car was not sold until 7/07 how is it possible that this car did not have the 7/70 limited powertrain warranty.I asked the person at chrysler and she told me thats something I would have to take up with a dealership.
Wow pretty dirty of chrysler only offering a 3/36 on a car that cost nearly 50k new,I was thinking of getting an extended warranty but the ones I've had in the past turned out to be a waste of money.
I agree on the extended warranties. Like I said, I have sold A LOT of them and made big bucks---more than double my money at the dealer level---standard in the industry---a $700 policy is sold for $1500 plus---It's called "back end" money. I had my reservations, but with the supercharger costing 6k new and 2k rebuilt PLUS labor and all the other AMG only parts IC, beefed-up trans, etc---I took the shot at 2.9 cents per mile. My car was 5 going on 6 years old when I bought it---only 900 miles but still had the age. From my days in repair, A/C problems start about 7 years or so and definitely by 10 years---no matter what the miles are. A/C systems are under 75 psi even at rest---Called static pressure. My guess is I will get my money back just on the A/C alone before 11 years since built---MB's A/Cs are not cheap. And although it sucks, no other high performance manufacturer gives a 7/70---Not Porsche, AMG Mercedes, BMW Ms, etc---and their cars cost even more. Chrysler was in line for this type of car---Actually, MB made that decision, I'm sure! Just the cost of "the grin"---permagrin that is!!! Let us know about the dealer and check to see if the nuts were turned on that 50 amp fuse. You will see marks from a wrench!!! Good Luck---Jimmy
Dam now you got me thinking I need to get my new baby an extended warranty.What is a good company to go with? On a side note from what I've read there is no longer a manufacturer of an aftermarket sc pulley.Has anyone tried using the pulley from an slk 230 .I have one in my garage from when I was trying to fab a sc setup for my triumph gt6.
ok I just got off the phone with Chrysler and they offered me 4yr/100k added care warranty for $1722 with $150 deduct. Seems like a good deal I think I'm going to make a call to the local stealer just to see if they offer a better deal but either way for that price I don't think I can go wrong.
Edit----Here's the guy---Just got off the phone with him---Number is good!!!!
Michael Case
Office (630) 231-3464
and the drama continues.Yesterday i spoke to the service manager and was told they replaced the PCM the fan was now kicking on but was not turning off on its own so they had to order another part.she told me they had to order a Fan module and its coming from Boston so if they ordered it yesterday there is a chance it will arrive today.At this rate I'll have a whole new cooling system before they are done.
!!! Good luck and let us know the out come---Did you call and get a quote from Mike Case? May pay to have that warranty after all, if people are going to throw parts at a car to fix it!!!
OK I think the drama is almost over with.I just spoke to the service manager and the stealership that has my car finally broke down and called Chrysler tech and got the answer someone else here had suggested.
Apparently the fan was drawing too many amps,it burned out the relay which in turn sent the bad signal to the PCM.So they have replaced the PCM,relay and now they are waiting for a new fan.If this finally rectifies the problem I should have my ride by the end of the week then once I can run it thru emissions I'll start on the performance mods .
oh yeah I'm definitely going with the warranty and fingers crossed I'm thinking they got it right this time seeing thru process of elimination there can be nothing else left to replace,funniest part is the service manager was actually chuckling while she told me how they replaced all 3 possible culprits.
---Mike will treat you right---Cool guy---And you are correct, NOTHING else to replace (they covered everything but the fuse and harness)---FYI---chances are only one of these parts were bad---they only needed to know how to use a multi-meter to figure out which part was bad---that and what the correct readings should have been---TEST, TEST, TEST is better (cheaper) than REPLACE, REPLACE, REPLACE.
Just a thought---Tell them that you want your old parts---In some states, repair shops must offer the parts to the customers---There is not a core charge on what was replaced, so you should be able to have them---not all three were bad---you may need one of them in the future---The PCM used is worth a few hundred bucks alone---Like I said, just a thought.
Finally picked her up today and you are not going to believe what the bill was for this fiasco.As the girl behind the counter handed me the keys I asked out of sheer curiosity what the total was.At first she told me the stealership I bought the car from was being billed $1223.00 not counting the $400 for the rental they gave me.So I figured maybe $3k total but had to ask for the whole bill and she started flipping pages in her hand and her fingers were flying on the calculator and the grand total was over $6800.00.I gasped with relief when she told me 2 of the parts they replaced were over $2k each.On the long ride home I noticed some whining from the rear when under torque climbing a hill . Is this the sound of the common driveshaft issue? Figure I'll have em check it out while still totally covered.
xfireohio
Jul 20, 2020 12:03 AM
rmcdaniel12
Sep 26, 2016 05:37 PM
MK2005
Nov 12, 2015 11:11 AM
