purchasing my srt6 yet another hiccup
Well I posted earlier about my search for an srt6 and finally the dealer gave me the deal I was looking for but upon delivery there is a slight snag.the vehicle in question is an 05 srt6 with a hair over 40k miles.The dealer agreed to deliver the car to me today because I live about 70 miles from them and I'm in Ct and the dealer is in RI.The salesman gets here and I get in the car to take it to the emissions station which is mandatory here to register a car.I notice the A/C isnt blowing cold and the low coolant light is on.Luckily I hadn't signed the final paperwork yet so the salesman makes arrangements for us to take it to a local dealer and they tell us it needs a PCM which of course the seller is going to pay for.they were kind enough to get me a rental while I'm waiting for my new ride.My question is will installing a new PCM send out codes when they run it thru emissions? I remember my explorer was a pain in the neck I had to drive it about 200 miles to run the computer thru its cycles before the emissions station would test it.Anyone have any experience with this ?
Sorry, I have no answer to your question, I'm sure another member will chime in.
If you don't see water under the car. The most common cause for a re-ocurring low coolant light is intercooler leak, this is an $1800 repair unless you do the work yourself, then your looking at $1100.
Wow now I'm wondering if the tech misdiagnosed the problem.Originally we were told that the fan wasn't coming on when it should so they said they had to test the sensor relay and fan itself.About an hour later they let the salesman know it was the PCM,they had to order it and it would be there in 3 to 5 days.The chrysler dealership that diagnosed the problem is not the one I'm buying from since it was about 50 miles away.I'll definitely mention the IC leak possibility.Back to my original question I know some vehicles after their comp has spit out a code and it has been cleared there is a time period you need to drive the car/put in a certain number of miles to allow the comp monitors to cycle.I know emissions stations here wont pass your vehicle until the comp is reading all cycles performed.I ran into this problem with my explorer,will replacing the PCM cause a comp reset?
I havn't heard of any PCM's needing to be replaced. I would have the dealer complete the emisions test as part of the purchase. I don't know your state emissions laws, but in many states the dealer is responcible to correct the issue if the vehicle fails the emisions check.
To answer your question about the computer. Yes like any OBDII computer when it is reset (and it will be) you must meet certain driving conditions prior to the computer being ready for emissions testing.
If you google you can find out what tests the computer is looking for.
thanks for the info does anyone know the parameters you have to put the car thru to clear out all the monitors? I remember with my explorer there was a certain set of things you could do to avoid having to actually drive the car for 500 miles before they cleared out.I'm more concerned with the possible IC leaking.The same coolant that is circulated thru the engine and radiator is shared by the IC correct? So a pressure test should detect an IC leak since there is nothing leaking to the ground.
thanks for all your help and info guys.I just spoke to the service manager and asked if the coolant level was low or was the light on for a fan failure and I was told it was not from low coolant it was because the fan was not kicking on.I then said this is a commonly misdiagnosed issue and she said the tech tested both the fan and the fuse.I asked if it was also low on coolant and she said no but didn't sound too convincing so for peace of mind I called the stealership I am buying it from and told the service manager there I want them to perform a coolant system leak down test.Worst case scenario I have to do the test myself and then take it back while its still under warranty I have a leak down kit here.
The dealer replaced my pcm 2 years ago while still under warranty, and they gave it back to me without any problems since. Then of course I had to have Eurocharged upgrade the software again.
Interesting,the stealership says the PCM is considered an emissions part and is covered under 100k emissions parts warranty.I thought these cars came with a 7/70 powertrain warranty?
So what they are saying is that the car did not come with a 7/70 but this part is considered part of the emissions system.I will get a 90 day 3000 mile warranty by law from the stealership I'm buying it from anyway.
