Can you identify this?
Old Oct 13, 2011 | 05:35 PM
dinasrt's Avatar
Default Can you identify this?
I found this on my garage floor where we park the srt6. I'm not certain what it is, or if it is even a part off the Coupe or not. It looks like some type of bumper stop/spacer? It may have been kicked there from another project or piece of equipment from the shop, don't know. Hopefully one of you may recognize this piece. I'm not as familiar with the understructure and suspension as I should be.P1010278.JPG
Old Oct 13, 2011 | 05:59 PM
Mike-in-Orange's Avatar
Default Re: Can you identify this?
Looks one of the rubber feet from my Rhino ramps. Do you have a set of these ramps that you've used recently, for an oil change perhaps?
Old Oct 13, 2011 | 06:11 PM
magredvet's Avatar
x2 on the rhino ramps ........
Old Oct 13, 2011 | 06:25 PM
dinasrt's Avatar
[quote=Mike-in-Orange]Looks one of the rubber feet from my Rhino ramps. Do you have a set of these ramps that you've used recently, for an oil change perhaps?[/quote
Bingo. Exactly Mike, thank you. I had it up for a coolant flush. I've only used the ramps a few times since I've had them, and never bothered looking at the underside. That's a relief, . Bob
Old Oct 13, 2011 | 06:28 PM
kingkub57's Avatar
Pad for the jack ???? check for all of your jack pads on the bottom of the car.
sorry answered to late, never had rhino ramps
Old Oct 13, 2011 | 07:20 PM
dinasrt's Avatar
Actually, I briefly thought that but then remembered what they look like and that they are hard plastic, not rubber. I use a hard rubber pad (piece of horse stall mat) between the floor jack and the jack location pad to protect it from damage. Thanks for the response.
Old Oct 14, 2011 | 02:33 AM
horse mat....now that is a great idea. I have some at the farm I have used yet. I am going to cut some small pieces just for that....thanks. I have splintered enough 2x4 pieces of wood lol...
Old Oct 14, 2011 | 09:24 AM
The white piece of plastic on the jack locates inside the jacking pad on the car why would you want to get rid of the positive location? That would be dangerous as the car could slip off the jack.
Old Oct 14, 2011 | 10:13 AM
dinasrt's Avatar
That material is damn near bullet proof; at least horse proof anyway. I cut mine a couple inches or so larger than the diameter of the round lift plate of the floor jack so it's not critical if it's off a little one way or the other. It conforms, spreads the load, has great bite, and like you said; won't split.
To 180: This pad is to protect our protectors. It's also way safer w/ it's better bite.
Old Oct 14, 2011 | 10:21 AM
I get you.
SRT6_Roadster
Sep 24, 2015 04:40 AM
NORDVIK72
Aug 30, 2015 08:22 AM
NORDVIK72
Aug 25, 2015 11:43 PM
Doyen
Mar 25, 2010 02:56 PM
gggggoalie
Jun 1, 2006 12:24 AM
