Scary and just in time for the holiday
Old Oct 26, 2011 | 01:49 PM
waldig's Avatar
Talking Scary and just in time for the holiday
I had a failure of my pulley long ago and set it aside. Recently I popped it apart to see the gizmos inside. Here is a photo of the insides for your information and use.
When the crank spins it spins with a shaking as it speeds up and slows down each MILLISECOND. THis is due to the pulses from the crank being pushed by the pistons on their power stoke. Un checked this vibration will hit the resonance point of the crank, causing it to flex and eventually CRACK and fail completely.
The rings spin free in the pulley and slip against the clutch discs to allow the rings to catch up to the pulley speed during dramatic engine rpm changes, like a gear change.......
Pins lock the rings together, springs load and push the rings against the clutches.
Enjoy, Woody
Other photo shows the stock design for grins. WW
Old Oct 26, 2011 | 02:18 PM
tunaglove's Avatar
Default Re: Scary and just in time for the holiday
Question: where is all the mass to absorb the vibration. I can see how the elastomer holding the outer ring on the stock pulley would dampen. But don't see where the dampening happens on the 181.
edit: I see, that big shiny ring must be heavy.
waldig
Jul 31, 2017 09:46 AM
scheper
Aug 3, 2015 03:13 PM
Aug 3, 2015 10:16 AM
waldig
Jul 30, 2015 07:39 PM
Ralph289
Jul 26, 2015 12:52 PM
