supercharger lag
Old Oct 30, 2011 | 01:57 PM
bucksarrow's Avatar
Default supercharger lag
Is there any way to get rid of supercharger delay at off idel takeoff?
Old Oct 30, 2011 | 02:05 PM
linstr63's Avatar
Default Re: supercharger lag
replace ic pump
2 things could be happening, but need more info. If it is just that little throttle hesitation you don't like, then a "sprint booster" sold by one of our forum members would take care of that. Aren't cheap. SRT SIX is the forum member you need to talk to. The other problem could be the inner cooler pump. This can cause a lack of power, or intermittant power loses. In this case you need a new pump, stock bosch replacement, CM30 Johnson, or a Ford Lightening pump will work as well. Needswings can supply those pumps as well. www.needswings.com More info would help
Old Oct 30, 2011 | 02:14 PM
velociabstract's Avatar
What the others said and one other thing I can think of. These "fly by wire" cars all have a lag when you put the car in drive or reverse, or switching between the two. It's part of the stock programming. I find it aggravating but it has it's reasoning behind it.
Les
Old Oct 30, 2011 | 03:57 PM
NeedsWings's Avatar
the s/c clutch kicks in around 1500rpms, do you really want to blow away the tires sooner than that?
Old Oct 30, 2011 | 05:10 PM
ModlessG's Avatar
Try a throttle reset I know its on the site here somewhere. You insert the key.Turn it most of the way on with out starting the car. The dash lights and stuff should be on. put the gas to the floor (my favorite part) Hold it there for 5 seconds. Turn the key to the off position but do not remove it. let your foot off the gas pedal.wait 2 minutes for a full reset.Then you can drive I do this whenever the car feels sluggish.
Old Oct 30, 2011 | 07:02 PM
I have a sprint booster for 199.00 just incase u want your tires to turn faster in the first 60' jim
Old Oct 31, 2011 | 05:41 PM
jsaredwings's Avatar
hey jim ill take that sprintbooster if its still for sale? paypal work? ill send a PM as well
Old Oct 31, 2011 | 07:01 PM
sent pm,, it is yours, jim
Old Oct 31, 2011 | 08:02 PM
jasardwings wants a the selectable type so mine is still for sale,, jim
Old Oct 31, 2011 | 08:47 PM
waldig's Avatar
Talking Re: supercharger lag
I have and never saw a benefit to the selectable booster. The lag drove me crazy so I added two throttle bodies and now have a quicker response with some ....some not a lot but some improvement. Woody
Old Nov 1, 2011 | 11:26 AM
msheredy's Avatar
You do understand that the supercharger needs to reach a certain RPM to effectively start cramming air into the engine right? And as Rob stated it doesn't engage until 1,500 RPM.
Old Nov 2, 2011 | 11:20 AM
dinasrt's Avatar
According to Woody's video, it comes on around 1,300. Supercharger testing on an SRT-6 - YouTube
Old Nov 2, 2011 | 11:33 AM
dinasrt's Avatar
Hey Woody, In my last autocross and on two separate runs I got a very long delay in the exact location on the track. It was after a fast/hard 90 going into the last slalom headed for the finish where I asked for nearly full throttle. I'm wondering if I've finally gotten fast enough to experience the YAW sensor that you have talked about, or I need to change my IC pump out. The delay was like 2 seconds, then slowly came up to speed. This killed an otherwise great time I had going on.
Old Nov 2, 2011 | 01:52 PM
waldig's Avatar
I can be heard yelling Delay Delay Delay three times before the car started to go. Since then I added the T/B design with ROBS assistance and added a switch on my YAW sensor. I beieve your experiencing the throttle delay. I go into corners with the brakes on and the gas to have it ready for the next turn..............anticipate is the best method. Woody
Old Nov 2, 2011 | 01:58 PM
tighed1's Avatar
I anticipate a Woody cure for this problem one of these days!
Old Nov 2, 2011 | 11:07 PM
dinasrt's Avatar
So you're saying the YAW sensor is what creates this throttle delay? Did the switch on the YAW sensor alone help a lot? Obvious? I have the sprint booster set in race mode when autocrossing but this is the first time I've experienced such an extended delay like this.
Old Nov 3, 2011 | 05:18 AM
Well, we went from throttle delay to full race mode...hope that helped...lol...
Old Nov 3, 2011 | 06:26 AM
waldig's Avatar
I believe that chassis managment was holding me back so I switched off the yaw sensor, seems to assist, read up on the yaw to see how it hits the brake and kills power to save you from you. Woody
Old Nov 3, 2011 | 12:13 PM
dinasrt's Avatar
Thank you. This is next on my X list. I truly believe this is losing me a full second or two in lap time. I look forward to some results w/ this offswitch, and saving myself if need be and not the car thinking I need saving, lol.
gblack32
Sep 7, 2016 08:27 PM
zackman62
Nov 6, 2015 12:37 PM
UNDER PSI
Nov 1, 2015 09:39 PM
tom2112
Oct 26, 2015 08:18 PM
FiftyThree033
Jul 26, 2015 09:24 PM
