SRT-6 SC & CEL Issues
Old Mar 17, 2012 | 09:25 PM
JoMac's Avatar
Default SRT-6 SC & CEL Issues
Hello SRT-6 Crossfire Owners,
I purchased this car over 2 yrs ago w/25K, and now it has 30K.
In general the car ran great until recently.
Sometimes when I drive with a fully warmed engine, and go to accelerate, it would seem the Supercharger doesn't kick-in like it normally does ( slight loss of power ).
After reading the Forums here, it appears it could be the Intercooler Pump ( No Engine Light )...Might have to invest in another IC Pump.
Last week the same thing happened, but this time with a ( Engine Light ). I had a OBD Reader, and it said the TPS.
Is it possible that a bad Intercooler Pump would give a TPS reading on the OBD ?
I have also put in 91-93 Octane, but I believe many of these stations here use E-85...I recently read the Owners manual, and it said not to use E-85. I wonder if this would also affect the TPS sensor or IC Pump.
I went ahead and cleared the codes, and will see if it comes back again.
Any info would be appreciated.
Old Mar 17, 2012 | 11:28 PM
Wedge's Avatar
Default Re: SRT-6 SC & CEL Issues
Yep bad IC pump. Definatley will cause the supercharger to not kick in. Many of us have had to replace it.
I can't speak to the throttle position sensor. I'm sure someone else will help out here.
Old Mar 19, 2012 | 12:22 AM
houston's Avatar
Smile Re: SRT-6 SC & CEL Issues
I had the same thing happening with my monster. Sounds like an easy fix.
Old Mar 24, 2012 | 12:46 PM
JoMac's Avatar
Hey Guys, thanx for the info and will look into that IC Pump...
Old Mar 24, 2012 | 01:27 PM
houston's Avatar
I just bought a replacement Bosch pump and a DCAI (DUAL COLD AIR INDUCTION) from Needswings yesterday.WOOHOO!!!
Old Mar 24, 2012 | 07:29 PM
kingkub57's Avatar
Have you done a throttle reset yet ? if not use the search feature for resetting the sensor. This might help you, also look the code up for what other problems that may be related to it, and go from there.
Danyuhl
Nov 2, 2019 05:18 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
Aug 5, 2015 12:52 PM
itsky
Aug 4, 2015 10:35 PM
itsky
Aug 1, 2015 03:45 PM
