Confirm my IC pump problem?
Old Mar 20, 2012 | 10:40 AM
Romio's Avatar
Question Confirm my IC pump problem?
Was out driving last weekend, highways and back roads. I did the throttle reset before I went out. On the highway rolling about 60 I pinned the throttle down, slow acceleration, way too slow. That happened once. Another time I downshifted into 4 and pinned it and I was thrown back with power. Another time I was stopped on a dead end, put it in first and pinned it down and had full power. I only seem to have a lack of power from a roll when warmed up. IC pump? Only other time I noticed it was accelerating up a hill from 30 to 55 after being warmed up.
Old Mar 20, 2012 | 11:23 AM
beasticles's Avatar
Default Re: Confirm my IC pump problem?
Yes, sounds like the IC pump. Replace that and you should be back in business.
Old Mar 20, 2012 | 11:44 AM
Romio's Avatar
Any more definitive tests I can do before I drop the $?
Old Mar 20, 2012 | 03:34 PM
rtmopar85's Avatar
Its the pump. Replace it. Easy drive way fix. Can be done in an hour or two. I replaced with the cobra/lightning pump but you can buy the original or the johnson as well. Just call Needswings they will take care of you quick.
Old Mar 20, 2012 | 05:49 PM
pump.... 99% of the time 1% is the temp sensor itself....
Old Mar 20, 2012 | 10:08 PM
JesseJamessrt6's Avatar
I had a situation like what is being described here one of the few times I had mine out. I thought for sure it was transmission fluid level though. Still haven't gotten around to checking it yet.
Do any of you guys have a thread that you could recomend that I read up on that explains how the IC pump not pumping causes irregular throttle response? Is it just heating up the air that much to cause vapor lock?
Old Mar 21, 2012 | 08:23 AM
Romio's Avatar
Ok im waiting on Rob from NW to invoice me.
Old Mar 21, 2012 | 03:24 PM
Well Jesse, take it from ole' Doc Holliday....the pump doesn't pump enough fluid to cool to the S/C, so the temps go up setting off the temp sensor on the S/C, which sends a signal to shut the S/C down until the temp readings go back down within safe operating temps...so that sensor will give you the power as well as take it away if it hit the critical mark....this make it buck like a bronco if it is shutting down/turning on....
Old Mar 21, 2012 | 03:25 PM
[quote=oledoc2u]Well Jesse, take it from ole' Doc Holliday....the pump doesn't pump enough fluid to cool to the S/C, so the temps go up setting off the temp sensor on the S/C, which sends a signal to shut the S/C down until the temp readings go back down within safe operating temps...so that sensor will give you the power as well as take it away if it hit the critical mark....this makes it buck like a bronco if it is shutting down/turning on....
Old Mar 25, 2012 | 10:41 PM
BenEbbs's Avatar
If I buy an srt6, should I just go ahead and buy a new Ic pump? It seems like these things burn out every month.
Old Mar 25, 2012 | 11:00 PM
srtswizz's Avatar
Check the fuse to the IC pump also, mine had blew and that was the only reason for my IC pump issues and not the pump itself.
The other issue if it is the fuse is why did the fuse blow? I had no clue but 2k-3k miles later its still running fine.
Old Mar 26, 2012 | 12:07 PM
Thank you Dr. very clear summary.
Old Mar 27, 2012 | 09:29 AM
klong's Avatar
I've had my SRT since 2009 and haven't had to replace the IC pump yet.
KL
gblack32
Sep 7, 2016 08:27 PM
northwest_crossfire
May 30, 2016 05:19 PM
velociabstract
28
Oct 28, 2015 12:46 PM
BrenLW
Aug 5, 2015 04:53 AM
ja.nko
Jul 10, 2015 03:21 PM
