rough idle / car dies
Old Apr 30, 2012 | 07:45 PM
gregtwelve's Avatar
Default rough idle / car dies
I am having a problem with my SRT-6, 8000 miles. About a month ago I was driving around 40mph and the car dies. Pull over and it restarts but idles very roughly with a bad miss. It seems to smooth out with higher RPM. It gradually ran a bit better and managed to get it home. I did some research on this forum and thought it could be the CPS. I ordered one and a week later installed it. After start up I had the same bad idle, so I reinstalled the old one and figured I would keep it as a spare.
Went back to the forum and found some posts about a weak battery causing sensors to malfunction due to low voltage. The battery might have been original so I replaced it and presto..car ran great. It is only a weekend car so 2 weekends later this past Sat. I left my driveway and now the rough idle is back. I pulled back into the driveway, turned off the ignition and tried to start it again and -nothing - would not crank.
I tried 2 times and the 3rd time it started, but with the bad idle.
I am thinking of doing the RCM resoldering this weekend. Any other ideas? Thanks in advance.
I
Old Apr 30, 2012 | 09:05 PM
The Beep's Avatar
Default Re: rough idle / car dies
I'ld take a hard look at the intake temp sensor. It'ld take 5 minutes to remove and reseat it and and if it pulls out easily, I'ld replace it. A new one runs $35-$50.
I had very similar symtoms as you are having where the car would run rough and konk out.
Good luck.
Old Apr 30, 2012 | 09:32 PM
gregtwelve's Avatar
thanks, Ill check it. I saw a post about. will have to wait till the weekend.
Old May 1, 2012 | 08:07 AM
BLACKSRT-6's Avatar
What code/codes do you have?
Old May 1, 2012 | 09:13 PM
gregtwelve's Avatar
I have not had the codes read. There is no CEL. I am trying to avoid bringing it to the dealer. I might bring it to my independent mechanic. I know he'd rather not work on it but I'm sure he can read the codes. I'll post when this resolves.
Old May 6, 2012 | 02:30 PM
gregtwelve's Avatar
Well I resoldered RCM on Sat. and drove 1/2 hour right after that and drove almost an hour today (Sun.). The car ran great the entire time. Not one stumble or miss in the idle. I am almost ready to call it fixed but will wait a week or two to be sure. Does anybody know if a bad solder connection in the RCM can cause our cars to die intermitently and idle roughly in addition to the no-start symptom?
mhajek18
Dec 30, 2015 03:40 PM
mhajek18
Jun 17, 2015 01:35 PM
gobraves423
Jun 6, 2015 07:03 PM
blackc230
Sep 7, 2003 03:51 AM
MARK_UK
Aug 3, 2003 06:29 PM
