ASP 178 pulley + EC supercharger pulley
Old May 27, 2012 | 05:57 AM
Silverarrow's Avatar
Default ASP 178 pulley + EC supercharger pulley
Anybody running this combo? Would we need to upgrade the ball bearings in the supercharger except for the one sitting in the supercharger pulley?
Old May 27, 2012 | 08:44 AM
32krazy!'s Avatar
Default Re: ASP 178 pulley + EC supercharger pulley
ec pulley is comparable to the c3 65mm s/c pulley so no bearing upgrade is needed. i run the same setup in a fluidamper 178 and a c3. what you will see is fuel pump pressure drop at wot and the need for larger injectors to ensure no lean conditions. approx 20 psi boost in hot weather so far but the colder temps of fall will inc. boost and the need for a retune for the leaner conditions.
you will also see 40 to 50* higher iat temps when running the car at wot . temps rise very quickly.
Old May 27, 2012 | 09:16 AM
waldig's Avatar
Talking Re: ASP 178 pulley + EC supercharger pulley
Your fuel delivery will drop due to the increased intake manifold boost pressure --retarding or resisting the fuel pressure. Id suggest an adjustable regulator on the pump or increasing the air pressure at the fuel pump to adjust the pressure setting of the factory regulator.
The stock injectors will flood you motor if the rail pressure is a bit higher, no need for injectors. Talk to Needswings Rob for more details on your setup. I had as high as 25 psi and pulled F/A in the 9's before I got the settings undercontrol. Woody
Old May 27, 2012 | 10:13 AM
Thanks
I will have the following setup:
- 550cc injectors and fuelrail from TTM
- SL55 AMG fuelpump
- SuperCooler with 5/8" ID
- Extra heat exchanger in front
- Johnsson CM90, 17.2GPH
Don't think that the intake temps will be a problem due to upgraded intercooler.
Old May 27, 2012 | 10:25 AM
Basically the only thing that has to be upgraded in the supercharger are the bearings, or I'm I wrong?
I will take mine apart within two weeks and check if I can find bearings that are good for 20000+ rpm, then we will have a safe mod even when the supercharger reaches rpm as high as 17000rpm.
Old May 27, 2012 | 10:28 AM
grip grip's Avatar
Originally Posted by Silverarrow
Thanks
- SL55 AMG fuelpump
I'm running stacked also. The 550cc injectors, rail, and pump solved all my lean issues (links are in my signature) and its a very simple solution.
Old May 27, 2012 | 10:38 AM
tunaglove's Avatar
Inside the supercharger? The bearings that go through the gearbox are sealed and the gears are pinned. There are two bearings on the rotor side that look very high quality. I don't think there are any better parts available.
Old May 28, 2012 | 05:30 AM
32krazy!'s Avatar
also the supercooler is a larger heat exchanger not an upgraded intercooler. to date there isnt anything availble for the intercooler
Old May 28, 2012 | 04:34 PM
Yes, I know. I have ordered a custom made intercooler. Little bit wider and longer then the original one.
Was at the phone with a Swedish company who maybe have some highspeed bearings for our s/c pulley
Old May 28, 2012 | 04:40 PM
grip grip's Avatar
Please share the knowledge at least regarding the intercooler.
Old May 29, 2012 | 01:22 AM
I will get back to you regarding the intercooler. As soon as I have tested it and it shows better performance then the orginal one I will let everybody in on it
Old May 29, 2012 | 03:02 PM
JesseJamessrt6's Avatar
subscribed
Old Apr 11, 2013 | 12:26 PM
Billy22Bob's Avatar
bumpity bump
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
