Anyone got a DIY method for compression testing?
Old Jun 16, 2012 | 05:33 PM
Billy22Bob's Avatar
Default Anyone got a DIY method for compression testing?
Had a search - no luck except for some figures here....
https://www.crossfireforum.org/forum...t-results.html
Was wondering if there is a good test where I can run through the cylinders one by one.
AFAIK stock cam - stock car
Obviously looking for ring and valve seat wear - 80k Miles - but obvious sludge problem in the process of cleaning up - looking at options.
If Compression down - another nail in the coffin towards a rebuild - if Compression - good - maybe simple cleanup.
Manual says....
"......SLK32 - Compression should not be less than 689 kPa (100 psi) and not vary more than 25 percent from cylinder to cylinder."
But I'd like to compare against factory spec. whatever that is - still searching. Maybe MB would relinquish the records...;>)
Old Jun 16, 2012 | 09:55 PM
32krazy!'s Avatar
Default Re: Anyone got a DIY method for compression testing?
coil packs disconnected and pull the fuel pump fuse. use a compression tester with a flaxible hose and a friend to turn the engine over. same as any other engine
Old Jun 17, 2012 | 05:48 PM
Billy22Bob's Avatar
I heard mention about the throttle body needing to be WOT as well?.....is that correct?
Old Jun 18, 2012 | 05:05 PM
70GS455's Avatar
Yes. While cranking, let it hit for 3 or 4 "puffs"
Old Jun 19, 2012 | 09:02 AM
tunaglove's Avatar
I forgot to open the throttle body when I did that test. It still worked but took longer to pump up. Pull the fuse to the fuel pump. Take off the coil packs and plug wires and just do one cylinder at a time. I'm curious to see where your pressure is at compared to mine.
TerryR
Dec 13, 2019 03:27 PM
onehundred80
Aug 6, 2016 12:03 PM
UNDER PSI
Nov 1, 2015 09:39 PM
Sep 28, 2015 07:40 PM
tritongreen
Sep 18, 2015 07:32 AM
