piggy back cranck position sensor
Old Oct 27, 2012 | 06:50 AM
fahed bassem's Avatar
Default piggy back cranck position sensor
I am in the process of installing a piggyback on the side, to use only when spraying nitrous.
I will put few degrees back on timing for safety reasons when on nitrous.
the piggyback is communicating with the cranckposition sensor. Does any body know, how many teeth
the cranck position is reading? it it 60 teeth and 2 flats or is it 30 teeth 1 flat, and 30 teeth and one flat? without inputing the right value in the piggyback tune, it is making the car having cranking problems once in a while.
thank you.
Old Jun 21, 2015 | 07:48 PM
bdh's Avatar
bdh
Default Re: piggy back cranck position sensor
Did you ever get it working correctly?
I want to do the same and would like any info you can provide.
including which one you bought and install suggestions
Thanks
Barry
KDW4Him
18
Sep 1, 2021 05:47 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
oldvintagedude
Aug 14, 2015 06:20 AM
Mark McKay
Jul 17, 2015 01:18 PM
Rusty475
Jul 13, 2015 10:03 AM
